how many subwoofers?
Discussion in 'Speakers & Subwoofers' started by RussD, Feb 25, 2004.
  1. RussD
    RussD Agent
    Feb 24, 2004
    26
    how many times can you split a subwoofer output? i have def-tech 7001's, supercube reference and sunfire mkii. can i split signal four times or should i just run 7001's full range and run y-connector for sunfire and supercube? anyone running similar setup? russ
  2. Robert Cowan
    Robert Cowan Supporting Actor
    Nov 10, 2003
    504
    see if you have any line-outs. you could use those for your fronts, they have a crossover... then split the LFE for subs.
    but if you wanted, you could split it 4 ways.
  3. RussD
    RussD Agent
    Feb 24, 2004
    26
    thanks robert. i guess my concern was if splitting signal so many times would degrade or distort signal in any way, or does signal weaken with every split?
  4. Robert Cowan
    Nov 10, 2003
    504
    to some degree, but at your level you should be fine. but my first suggestion is best. go pre-out into the mains, and then split your LFE.
