How many shows put out Dolby Digital output.
Discussion in 'Archived Threads 2001-2004' started by Tan_U, Oct 31, 2001.
  1. Tan_U
    Tan_U Stunt Coordinator
    Sep 17, 2001
    67
    I've ordered Dish network top 100, is it worth it too spend $100 more to get Dolby Digital output receivers, how many shows will actually send out Dolby Digital signals?
  2. Jon_T
    Jon_T Agent
    Jun 3, 2000
    28
    Starz East, Showtime East & West, HBO East, the HD channels and 10 PPV channels are in DD. I have not heard of any of the regular "cable" channels broadcasting in DD so Dish does not have those channels in DD. If you plan on watching any of these channels then it would probably be a good idea to get a DD receiver.
  3. John_Bonner
    John_Bonner Supporting Actor
    Oct 25, 2000
    664
    Tan,
    Check here: DD 5.1 on TV
    JB
    My baloney has a first name it's H-O-M-E-R my baloney has a second name it's H-O-M-E-R
  4. Ken Stuart
    Ken Stuart Second Unit
    Jan 31, 2000
    468
    Another way of putting it is that if you don't plan on subscribing to Showtime, HBO or Starz, then all of your Dolby Digital programming on DBS will be PPV movies (and in theory, PPV music events such as concerts).
  5. Tan_U
    Sep 17, 2001
    67
    Thank you, I'll wait until I can afford an HDTV receiver to receive Dolby Digital, the Echostar 301 will do for now.
  6. Vasanth B
    Vasanth B Stunt Coordinator
    Aug 18, 2001
    61
    Keep in mind that you can still take advantage of a digital output on the receiver even on normal stereo channels. It will just be output as PCM data and your receiver will convert it to analog. This allows you to use the usually superior home theater receiver DACs. You'll should get less noticeably less hiss than with the analog outputs of the 301.
    BTW, I have the 301 and the sound quality is good, but there is noticeable hiss.
  7. Dan B
    Dan B Screenwriter
    Sep 17, 1999
    1,389
    That's a good point. Simply using this type of connection can improve the sound quality on all channels.
    -Dan B
  8. KenA
    KenA Stunt Coordinator
    Mar 28, 2000
    109
    Massapequa, NY
    Ken Appell
    Which receivers output DD? Optical or coax?
    »ken«
