How many receivers per LNBF
Discussion in 'Playback Devices' started by Jay H, Oct 23, 2005.
  1. Jay H
    Jay H Producer
    Mar 22, 1999
    5,654
    33
    Pittsfield, MA
    Jay
    I have a Dish 500 with a dual LNBF switch installed that was installed when I signed on for the Dish At-Home service a few years ago (the rental one). I now own 2 receivers (a 501 and 508 I bought used) and wondering how many more receivers can I install with the same LNBF, switch, etc.
    Jay
  2. Robert_J
    Robert_J Lead Actor
    Aug 22, 2000
    8,303
    59
    9,110
    Mississippi
    Based on this, it sounds like you have a Twin LNB. That's a pair of dual LNB's and a pair of SW21 switches all in a single housing. The two outputs allow you to connect a pair of receivers or a single dual tuner receiver. If you want more, then you need either a Quad LNB (4 outputs) or a pair of dual LNB's and external switches. The Quad is easiest to work with. The dual LNB's is the most flexible and allows for more than four receivers.
    -Robert
