Niel_JL
- Mar 24, 2002
Still pondering which receiver to get. Right now I am leaning toward the onkyo 600, mainly because it is affordable and has component video. However some of you have suggested that I skip the component video and put that money towards better speakers. Well that sounds like a good plan but I gotta find a receiver that will hold my components.
Here is what I have to hook up if I skipped component in/out:
Sampo DVD player: component input directly to TV. Toslink to receiver.
2nd DVD player: composite or S-video to receiver (video only)/ monitor out to TV. toslink or coax to receiver
VCR: composite to receiver/ monitor out to TV
Satellite: composite to receiver/ same as above
Playstation: composite to receiver/ same
cd player: audio to receiver. Using "B" speakers.
"A" speakers will be 5.1 set up
That's the set up if I didn't get a receiver with component video
If I got the 600, I would use the two component inputs for the DVD players, that would be the only difference
Having said that, I couldn't find another receiver in that price range that would best suit my needs. Perhaps you guys know otherwise.
