How Many Lines of Resolution
Discussion in 'Archived Threads 2001-2004' started by Don, Dec 18, 2001.
  1. Don
    Don Second Unit
    Jun 30, 1997
    374
    is reccomended for a TV to have so a DVD Player will work properly with it. Don,
  2. John Garcia
    Jun 24, 1999
    11,571
    24
    NorCal
    Lines of resolution has nothing to do with a DVD being able to operate with any given TV, unless you are talking about HD input and a progressive scan DVD player.
    The TV having the appropriate connections to hook up to, is very important, however. A basic DVD will hook to, and work with, nearly any TV that at least has composite or S-video input, preferably component video. Not too many can output to coax (cable), though there are adapters for some brands/models.
  3. Darryl_B
    Darryl_B Stunt Coordinator
    Mar 2, 2001
    66
    however,
    A widescreen TV set will offer more resolution from most DVDs than a 4:3 ratio set.
    DB[​IMG]
  4. Don
    Don Second Unit
    Jun 30, 1997
    374
    ok i'm looking at getting a pog scan dvd player any reccomandations on how many lines the tv should have. Don,
  5. MichaelG
    MichaelG Second Unit
    Jul 10, 2000
    322
    don, any TV that will accept a progressive signal from a DVD player will work. The lines of resolution is largely a number used just for marketing and is not exactly what you think it is. What you really need to decide is whether you want to buy a Widescreen or standard TV. You can get both that will accept a progressive scan signal.
    So, don't worry abuot the lines of resolution number, if the TV accepts a progressive scan signal then you should be fine.
