How low can surround speakers be placed?
Discussion in 'Archived Threads 2001-2004' started by MoG, Apr 1, 2002.
  1. MoG
    MoG Stunt Coordinator
    Jun 29, 2000
    50
    Hi,
    I'm planning on buying either 2 or 4 Anthony Gallo Micro's to use in my HT setup. The problem is I don't really have a great spot for them. [​IMG]
    Gallo makes stands for the speakers that are 3 feet high. That would put them just at ear level.
    Is that too low for side and/or rear surround direct radiating speakers?
    Thanks.
  2. Frank Zimkas
    Frank Zimkas Supporting Actor
    Mar 10, 2002
    888
    Everything that I've read on the subject (magazines, mfg. spec.'s, this web site, etc.) suggest placing surround (side & Rear)speakers above and slightly behind the listener for the best sound.
  3. Dan Steffen
    Dan Steffen Stunt Coordinator
    Dec 9, 2001
    55
    FWIW - dolby suggests 2-3 feet above listener's level
    dolby site
  4. ChrisMatson
    ChrisMatson Cinematographer
    Dec 14, 2000
    2,181
    110
    I have my surrounds at ear level on some cheap stands. Ideally, they should be higher, but in my aparment, there is no way to mount the (heavy) JBL S26s higher without doing some construction that my landlord would not appreciate. IMO, put them where you can and then calibrate with an SPL meter to ensure you are getting the proper sound level at your listening position. Dolby Labs may not think its ideal, and THX might not certify your home theater, but you should be happy.
  5. John Garcia
    Jun 24, 1999
    11,571
    25
    NorCal
    I have my mains and rears on identical stands, all at ear level, and it sounds great.
  6. Barry_B_B
    Barry_B_B Second Unit
    May 14, 2001
    453
    Good info, since I'll be moving to an apartment soon with the same issues [​IMG]
