How long should I make my sub?
Discussion in 'Archived Threads 2001-2004' started by Scott_Mill, Aug 7, 2001.
  1. Scott_Mill
    Scott_Mill Extra
    Aug 15, 2000
    15
    I have never built a sub and need to know how long should I make a 12" diam. ported sonotube sub with a driver like this:... and does a 75 watt amp sound like enough for this driver or should I find a driver that is more efficient
    Peerless 831727
    Fs = 22.3 Hz
    Qts = 0.34
    Vas = 136.2 liters
    SPLo 87.8 dB
    X-max = 9.0
    Power = 220 watts
    Box Liter Sealed/vented 40s/63v
    [Edited last by Scott_Mill on August 07, 2001 at 03:41 PM]
  2. Cees Alons
    Cees Alons Moderator
    Jul 31, 1997
    19,357
    293
    Cees Alons
    Scot,
    That isn't easy to answer. There are several programs to help you design a sub.
    Here's a good one for a start: WinISD (beta), by Juha Hartikainen.
    Look at this site: LinearTeam
    You must make yourself acquainted with it, but it's not really difficult. There are also several good books on the subject, e.g. The Loudspeaker Design Cookbook, by Vance Dickason.
    If I were you, I would download WinISD (freeware!) first and see how far you can get.
    Good luck.
    Cees
