How long are the LD Star Wars releases?
Discussion in 'Archived Threads 2001-2004' started by Chris PC, Oct 10, 2002.
  1. Chris PC
    Chris PC Producer
    May 12, 2001
    3,975
    How long are these two Star Wars releases including interviews etc LD?
    I own these LD's but I can't find running time anywhere except by playing the whole movie.
    Star Wars THX Faces?
    Star Wars: A New Hope (127 minutes)
    Empire
    Jedi
    SE box set versions 1997
    Star Wars
    Empire
    Jedi
  2. alan halvorson
    alan halvorson Cinematographer
    Oct 2, 1998
    2,009
    You know, you're right - I never noticed this. It's not on the SE box, the insert or the discs. But you certainly don't have to play the discs through to the end to calculate times - just skip to the ends and add 'em up! Also, many machines will display time played, time remaining and total time if the disc was so encoded (mine will even show frames played on a CLV disc) and I'm pretty certain the Star Wars SE box was - don't own the "Faces" version.
  3. Paul Bartlet
    Paul Bartlet Stunt Coordinator
    Dec 1, 2000
    88
    Chris, would you happen to know if you can still buy Star Wars on LD. I don't have, nor ever had LD, but would consider getting one for Star Wars without all that SE stuff.
    If so, I see ur in Ontario, could you point/direct to where [​IMG]
    doing a google search for "laserdisc toronto" not turning out to well :/
  4. Matt Stone
    Matt Stone Lead Actor
    Jun 21, 2000
    9,063
    Your best chance is to buy them off of eBay. I got the Definitive Collection for under 100 last May.
  5. Chris PC
    Chris PC Producer
    May 12, 2001
    3,975
    Try a WTB ad here on HTF or try AVS:
    http://www.avsforum.com/avs-vb/
    or try eBay [​IMG]
    Alan,
    That means I have to put in each and every side of each disc. Mind you its not too bad cause you just pause it and read the time, and then switch to remaining time and add them up. Its just a pain to insert each disc and flip sides. Thats lots of disc inserting and flipping! My player is a flipper 79 but I don't like making it flip just for that reason.
  6. David Norman
    David Norman Producer
    Oct 12, 2001
    3,183
    446
    OK, as close as I can get it. This is the total time for the discs including the trailers and supplements.
    Faces:
    Star Wars -- 128:52
    ESB -- 133:20
    ROTJ -- 139:17
    SE Box:
    SW (S1,2,3) -- 128:42
    ESB (S4,5,6) -- 130:38
    ROTJ (S7,8,9) -- 167:43
  7. Eric_R_C
    Eric_R_C Second Unit
    Sep 9, 2001
    254
    Paul,
    I got a Sony MDP 330 for $25 bucks, and the Definitive Collection for $77. I'm in the process of getting the THX "Faces" discs (got A New Hope sealed, don't want to open it [​IMG]) The Def. Col. I wanted just to have, but I'll watch the faces (fewer flips, until I get a Pioneer 504 or 704 [​IMG])
    Star Wars in PCM sounds GREAT! Much better than my VHS copies.
    BTW, I know we can't talk about bootlegs, but
    are the bootleg OT DVD's flippers? Or can bootleggers make DVD 9's ?
    I know they are copied from the LD's, so I like having the Masters [​IMG]
  8. Chris PC
    Chris PC Producer
    May 12, 2001
    3,975
    Cool. Thanks. I wanted to compare lengths and now I can roughly. I'll sorta have to watch em all again anyways. Have to. Huh. I want to....I just mean, I'll have to remember to record the minutes before each side flip [​IMG]
    Thanks young jedi's, may the farce be wiff you [​IMG]
  9. David Norman
    Oct 12, 2001
    3,183
    446
    I can give you the side times as they read off my display. I would think they would be the same for all
    machines though.
    THX CLV/Faces
    Star Wars
    1 -- 44:38
    2 -- 50:15
    3 -- 33:59 Incl supp
    ESB
    1 -- 42:08
    2 -- 43:16
    3 -- 47:56 Incl supp
    ROTJ
    1 -- 52:54
    2 -- 52:54
    3 -- 33:49 Incl supp
    SE Box
    SW
    1 -- 45:54
    2 -- 57:50
    3 -- 24:58 incl trailer
    ESB
    4 -- 51:48
    5 -- 54:21
    6 -- 24:29 incl trailer
    ROTJ
    7 -- 53:37
    8 -- 56:09
    9 -- 57:56 incl trailer and supplements
    (26:00 until the end of the credits + 31:56 for trailer and suppl. interview)
