how important pre/pro is in the system
Discussion in 'Archived Threads 2001-2004' started by Yoon Lee, Jul 1, 2002.
  1. Yoon Lee
    Yoon Lee Stunt Coordinator
    Jun 16, 2001
    162
    how important pre/pro in your system is? More or same to power amps? lower than CD player? even lower than cables? or even higher than speakers? What $3000 pre/pros can bring to you whereas $500 receiver cannot other than a billion tweaking options? My question is strictly on sound.
  2. Sihan Goi
    Sihan Goi Second Unit
    Nov 2, 2001
    442
    I'd have to say that next to the room acoustics and speaker systems/positioning, the preamp portion is the next most important, followed by amplification and source.
  3. Larry B
    Larry B Screenwriter
    Nov 8, 2001
    1,067
    Sihan Goi said
  4. John Royster
    John Royster Screenwriter
    Oct 14, 2001
    1,088
    Its part of the whole system an does have a significant impact. Meaning if you have nice speakers, good source, good power, but use a $500 dollar receiver as your pre-amp then you'll suffer.
    Noise floor/channel-separation and keeping an analog signal clean without messing with it are what a good pre-amp gets you. Its tough to get good two channel playback from a multifunction pre/pro, some of the nicer ones do a pretty good job.
    Also a nice pre/pro has really good DACs making all your digital sources shine as well.
    -edit- just re-read your post. in order of importance here's MHO.
    1) speakers
    2) room
    3) source
    4) pre-amp
    5) amp
  5. Yoon Lee
    Jun 16, 2001
    162
    Someone in this forum mentioned price for those DACs are relatively cheap compared to the prices for power amp parts. Then why are pre/pros are expensive? Is it because of all those license fees (Dolby, DTS, THX, and such)? Or, simply they charge more?
