how important/much better is dedicated pre/pros
Discussion in 'Archived Threads 2001-2004' started by Yoon Lee, Jun 27, 2002.
  1. Yoon Lee
    Yoon Lee Stunt Coordinator
    Jun 16, 2001
    162
    Ok, I have Denon 3802 functioning as pre/pro. Would a dedicated pre/pro would make big sonic difference compared to a receiver?
  2. Holger
    Holger Stunt Coordinator
    May 29, 2002
    87
    hi yoon,
    in one word: yes. IMO the pre amp section has way more influence to the sound then a separate power amp. of course a good power amp can also make a big difference but not the way like a good pre amp.
    regards, holger
  3. Martice
    Martice Screenwriter
    Jan 20, 2001
    1,077
  4. Yoon Lee
    Jun 16, 2001
    162
    Here is the list of equipments to evaluate. [​IMG]
    Denon 3802
    Rotel 1075 power amp (120w, 5ch)
    B&W 7NT + CNT main speakers
    Sony CE775 SACD player
    Transparent Cable all around
  5. John Royster
    John Royster Screenwriter
    Oct 14, 2001
    1,088
    With that list I would say YES a good pre/pro will make a good change as you have good power/speakers/source already.
    I have a 3802 and it is a pretty good at pre/pro duties. It does not compare to my adcom though as a 2-channel pre-amp. Never hurts to try before you buy!
    What are you trying to improve? Music or movies?
  6. Sihan Goi
    Sihan Goi Second Unit
    Nov 2, 2001
    442
    Definitely. The Denon 3802, while a capable receiver at its price point, can in no way compare to a separate prepro. I remember auditioning the Denon 3801, wanting to use it as a prepro. The dealer had it connected to an ATI 1505 amp, and I thought it sounded pretty good and clear, but then he switched to a cheap Parasound AVP1800 prepro, and the sound just came alive with better imaging and wider, more 3D soundstage. Of course, without doing a direct comparison I'd probably be pretty satisfied with the 3801.
  7. Jeffrey Chin
    Jeffrey Chin Second Unit
    May 22, 2001
    483
    WHAT SIHAN SAID
    SEPARATES RULE
  8. Yoon Lee
    Jun 16, 2001
    162
    John, music. For movies, I'm cool with what I'm already getting. BTW what're popular choices? I know Rotel 1066 is, but I don't feel comfortable spending more on pre/pro than on my power amp.
  9. Tony Lai
    Tony Lai Stunt Coordinator
    Mar 22, 2000
    244
    I do not understand why a capable receiver like a Denon 3802/4802 in a pre-pro config would suffer compared to say a Rotel 1066.
    It doesn't make much sense. In analog thru I would say yes but pure EX/ES decoding?
    T.
  10. Sihan Goi
    Nov 2, 2001
    442
    Many things in hifi/audio/HT don't make a lot of sense, they just happen. Go listen for yourself, and see if its different/better.
  11. Robert_Dufresne
    Robert_Dufresne Stunt Coordinator
    Mar 30, 2002
    246
    Yoon Lee
    If you hang around this site you will find that a
    lot of people think that receivers such as the denon
    3802 make very good pre/pros because they usually
    offer equal sound quality and more features and
    options for the money .
    The amp section of receivers is the most often criticized, the preamp section is imo as good if not better then separates in the same price range.
  12. kevitra
    kevitra Second Unit
    Apr 24, 2002
    364
  13. Martice
    Jan 20, 2001
    1,077
