How important is the physical smoothness of a port
Discussion in 'Archived Threads 2001-2004' started by Mike Dr, Mar 18, 2002.
  1. Mike Dr
    Mike Dr Stunt Coordinator
    Jul 30, 2000
    171
    I am currently building a sonosub, and I had to sand the inside of the port because the glue came out a bit and hardened. What I wanted to knwo is should i bother with very very fine sanding on the inside of the port to get it as smooth as possible or is it ok for it to have the consistency of slightly sanded plastic? Common sense tells me this is not very critical especially in a subwoofer...
    let me know
    thanks
  2. Mike Dr
    Jul 30, 2000
    171
    comon people.. you're reading the thread,just say yes or no [​IMG]
  3. Patrick Sun
    Patrick Sun Moderator
    Jun 30, 1999
    38,717
    463
    Knock yourself out, this is DIY, there are no limits. [​IMG]
  4. ThomasW
    ThomasW Cinematographer
    Nov 6, 1999
    2,282
    The walls of the port should be as smooth as possible.
