How Important Is That New Amp?
Discussion in 'AV Receivers' started by JustinP, Jul 7, 2003.
  1. JustinP
    JustinP Stunt Coordinator
    Aug 30, 2001
    99
    Is adding separate amplification really that important? Or is second to other upgrades, such as upgrading a music source.
    I ask, because I want a separate amp, but I have a terrible cd player (Panasonic A105 DVD player using digital coax out). Would upgrading my source to a decent CD player or a DVD player with good audio DACs be a better idea?
  2. Pete H
    Pete H Stunt Coordinator
    Mar 5, 2000
    52
    Upgrade order:
    Speaker
    CDP
    Preamp
    Amp
    or
    speaker
    integrated
    CDP
    and the room is more important than all of the toys.
  3. Jason.Soko
    Jason.Soko Stunt Coordinator
    May 30, 2003
    219
    I personally start at the cheaper end of the spectrum. Add the CD player. See how much better it sounds and where it's losing. Then upgrade to a better amp, see if it makes a difference, then finally add a nice set a speakers that match the amp. A crappy amp isn't going to do anything for the speakers. YOu might as well upgrade that first.
  4. Chris PC
    Chris PC Producer
    May 12, 2001
    3,975
    If your CD player is connected digitally, the CD player is nothing but a transport. How are the DAC's in your receiver? A better CD player might be better than your receivers DAC's but you'll need to connect via analog RCA's.
