StanleyW
- Feb 27, 2002
pretty much what the above states. thanks.
The only problem you may have is that some power amps like mine have a proprietary on/off trigger. Most use a plain jane 12v trigger though. It just means that you have to leave the amp on all the time.Or get up and turn it on and off manually.
It just means that you have to leave the amp on all the time.So Philip are you leaving your amp on all the time?
Isn't brand independence one of the key benefits of seperates?One of the benefits, yes, key benefits? Perhaps.
Isn't brand independence one of the key benefits of seperates? If I thought it was important that all components be the same brand, I don't think I'd have gone with seperates in the first place.I think the main benefit of separates is separating the functions of each piece away from one another. Different power supplies, different capaciters, etc. Each piece doing what it's suppose to do. The processor processing and decoding the sound, the amplifier amplifying the sound.
I often find that manufacturers design their gear to work in conjunction with one another, so do not discount the ability to have component synergy by matching the manufacturers amp with processor. Not to say that you cannot gain the same experience by going in another direction, but there is something to be said by getting the combo.
I agree with Phillip...I think brand independance is an advantage to separate components, but I think it is far from the key advantage.
Evan and Philip,
I agree with you that brand independence may not be a key benefit... at the outset. However, even if you start out with all components of the same brand, you still benefit rom future brand independence. For example, quite a few people today are buying Anthem AVM-20 processors and MCA amps. A few years from now, if Anthem is no longer a leader in the processor market they can easily easily move to whatever brand is. Or, if they want to move up to (say) a Lexicon processor, they can do so without replacing everything at once. Over the years, the brand independence provided by seperates becomes an increasingly important benefit.Man, you ain't kidding! My preamp recently died. Since I have separates all I had to do was buy a new preamp instead of a whole new separates system. Nice benefit.
