AaronNWilson
- Jan 28, 2001
I just picked up a digital spl meter over the weekend and I was calibrating my levels via the 3801 pink noise. However since I have sub set to no since I am using an external XO I guess it doesnt send out any pink noise for the LFE channel .
Well I found out that when I ran the pink noise at the 00 level my Klipsch RF3s seemed to be around the 95 dB range. I knew these speakers were efficent but boy they can sure pound the notes out.
Anyways I have all of my channels calibrated to 95 dB at 00 level. However the only way I could test the LFE level was by popping in the fight club dvd which showed the LFE setting to be at 100 dB at 00 (its a servo 15). Then I checked the DVD levels for the other channels and it was outputting around 88 dB at 00 level wheras the 3801 pink noise was putting out 95 dB at 00.
So now basically Im wondering how important it is to have the sub set to the 85 dB setting?
I tried putting the LFE setting down to the -10dB level but the sound just didnt have the authority that I have become accustomed to over the last few weeks with using the servo 15.
I guess the DVD pink noise was the most accurate since that is the medium I usually am watching, but this means even with the LFE at -10 I am still having the LFE calibrated to 90 dB at 00 whenever the specs call for 85 dB right?
What should I do about this?
Aaron
Aaron
