How important is Cinema RE-EQ?
Discussion in 'Archived Threads 2001-2004' started by Dave LR, Feb 1, 2002.
  1. Dave LR
    Dave LR Auditioning
    Sep 2, 2001
    4
    I know that all THX and some Denon receivers like the 3802 offer Cinema RE-EQ, supposedly to tame harsh soundtracks, but how important a feature is it? How many of you use it regularly? What brands and models of receivers have this feature?
  2. rodneyH
    rodneyH Supporting Actor
    May 22, 2001
    844
    I have a parasound pre/pro, I never use it, never. But I never use any DSP modes (besides the standard DD and DTS modes), I like to listen to music and movies in its most accurate form.
  3. James Zos
    James Zos Supporting Actor
    Jan 7, 2002
    725
    I have found that on a few dvd's, when it comes to dialogue, some vocals can tend to have a harsh edge on them. I tried the EQ feature, and it helped, but then it lowered the sonic quality for other DVDs (this is on a Denon 3802).
    In the end I decided that dropping the treble just a little gave me the best overall results. I leave EQ off.
  4. Brett DiMichele
    Brett DiMichele Producer
    Sep 30, 2001
    3,181
    Rodney,
    If listening to a poorly mastered DVD with Harsh Highs is
    "In it's purest form" then count me out.. Re-Eq is a wonderful
    feature for taming harsh highs on poorly mastered media and
    I do use it when I find a DVD has bad audio (Terminator 1
    comes to mind).
  5. Holadem
    Holadem Lead Actor
    Nov 4, 2000
    8,967
    I use it all the time. It removes the excessive "SSSSSSSSSS..." out of the sound, especially in my old room (hardwood floors). Now my new place is carpeted, so things sound kinda dull. I might therefore disable it.
    Holadem
  6. rodneyH
    May 22, 2001
    844
    brett, I guess I have never heard any of those BAD dvd's
  7. Christian Dolan
    Christian Dolan Stunt Coordinator
    Nov 26, 2001
    107
    I have a Sherwood with Re-EQ and I find it very useful, given that I have a very live room (hard wood floors, lathe-and-plaster walls).
  8. Jason Wolters
    Jason Wolters Stunt Coordinator
    Dec 18, 2001
    227
    One thing you may want to be aware of, is that when you turn this feature on your channel balance will go out the window. To verify this, break out the SPL meter and notice what happens, once you turn it on.
  9. Ted Lee
    Ted Lee Lead Actor
    May 8, 2001
    8,390
  10. KevinW
    KevinW Stunt Coordinator
    Dec 11, 2000
    187
  11. Rick Radford
    Rick Radford Supporting Actor
    May 12, 2001
    642
    Kevin,
  12. Lewis Besze
    Lewis Besze Producer
    Jul 28, 1999
    3,134
  13. Jon D
    Jon D Stunt Coordinator
    Sep 29, 2000
    166
    I never use it on my Onkyo 575x. Most DVD soundtracks are nearfield mastered now. I think Re-EQ was more useful in the laserdisc era, when soundtracks were usually direct dumps of theatrical printmasters. Re-Eq also has the nasty habit of causing dropouts and popping with some DTS tracks (It has happened to others and seems to not be limited to the 575x). Nice feature to have, but overall pretty pointless.
  14. Chip E
    Chip E Screenwriter
    Nov 25, 2000
    1,165
    So far, i've left it on, on my Integra receiver.. i'll have to play around with it, check it out on and off. It's all good with it on though. [​IMG]
  15. Lewis Besze
    Jul 28, 1999
    3,134
  16. Jack Gilvey
    Jack Gilvey Producer
    Mar 13, 1999
    4,948
    One of the main things that influenced my purchase of my Onkyo 575x was the presence of this feature, but I've never found the need to use it. This may be due to the fact that my system balance is slightly "forgiving" in nature anyway, which I much prefer.
    Also, I'm not much of a DVD collector, and I suppose if I had a bunch of older DVD's that weren't mastered as well as more modern ones I'm sure I'd reach for the button once-in-a-while.
  17. Ashley Burt
    Ashley Burt Extra
    Mar 11, 2001
    18
    I have a Integra 7.1 and have tried it both ON & OFF. Sound about the same I currently leave in on (default).
  18. Jason Wolters
    Dec 18, 2001
    227
  19. Brian O
    Brian O Second Unit
    Apr 27, 1999
    284
    I rarely use it on my Denon 3300, except on a few older DVDs that are excessively bright.
  20. Dan Hitchman
    Dan Hitchman Cinematographer
    Jun 11, 1999
    2,713
    Near field mixes: All the more reason why THX should allow Re-EQ to be turned on or off by the consumer. As far as I know at present, you turn on THX post processing and you are forced to use Re-EQ like it or not; you can't just switch that particular feature off.
    Dan
