How hot should my CPU be?
Discussion in 'Archived Threads 2001-2004' started by Rob Lutter, Apr 19, 2002.
  1. Rob Lutter
    Rob Lutter Producer
    Nov 3, 2000
    4,523
    Checking my BIOS, I see that my CPU temp is 48 degrees celcius when idle... is this a little high? Maybe I should swap out the 6000rpm Delta fan (that came with my Vantec CCK-6027D heatsink/fan) for a 7200rpm model (aka... the hair dryer [​IMG] )
    wadda you guys think? (I am using Arctic Silver 3 Thermal compound by the way, so that can't be the problem).
  2. Michael Silla
    Michael Silla Second Unit
    Jul 27, 2001
    313
    Honestly Rob, I think that temp looks okay. There are some Athlon XP owners who have temps in the 38 to 40 degree range when idling/ 45 or so under load. Cooler yes - but something really necessary to "sweat" over? No.
    My rig usually runs 48 at idle and 52 under load. Honestly, for those people striving for lower temps than these I have to wonder if it is worth it. If I only get 5 years out of my CPU vs the 7 that someone who has an "extreme cooling" setup then so be it. I would have long since passed that CPU along anyway.
    If you are into lowering temps overclocking or recreation even then by all means, sweat those "big C's."
    Michael.
  3. Randy_T
    Randy_T Stunt Coordinator
    Dec 18, 2001
    95
    Athlon XP's were designed to run cooler than T-birds. While my XP 1800+ hovers around 40 at idle and 46 under load with a stock heatsink/fan, my T-Bird 1.2GHz runs hotter at 46 when idle and lower 50's under load with a GolbalWin FOP38 heatsink/fan with Artic Silver II. In less you plan on overclocking, I also think your temps are fine.
    Randy T
  4. Kelley_B
    Kelley_B Cinematographer
    Feb 27, 2001
    2,324
    Rob unless you are overclocking the CPU then you shouldn't worry. You might want to look at your case airflow though....remember in the front bottom out the rear top.
  5. Salvador
    Salvador Second Unit
    Dec 4, 2001
    431
    what is your case temperature running at???
  6. Rob Lutter
    Rob Lutter Producer
    Nov 3, 2000
    4,523
    my case temp is around 30-32 celcius
  7. Jeff Braddock
    Jeff Braddock Second Unit
    Jan 26, 2002
    306
    This is a similar question to Rob's...
    after reading the posts I thought I'd check my cpu temp. It is 60 C! This seems awful high for a 500 mhz snail-a-ron. I checked the settings in bios and for the cpu fan it says "disconect" I tried to highlight it, but it wouldn't let me select it. It seems that my cpu fan is not running although it sounds like it is. Where my computer is it is hard to get to the back to unplug/plug in everything so I haven't opened the case yet. Do any of you have any idea what is going on/how to fix it? Thanks for the input.
  8. SteveBjr
    SteveBjr Stunt Coordinator
    Aug 7, 2001
    196
    Your computer may not have a CPU fan, older CPU's sometimes didn't even include fans. The fan you hear is probably the powersupply fan. As the CPUs got faster and faster heatsink/fan combos became a must to keep them running at safe levels.
  9. Jeff Braddock
    Jan 26, 2002
    306
    it does have a cpu fan
  10. JohanK
    JohanK Second Unit
    Jan 22, 2000
    478
    Jeff, is the fan working? I would take the computer cover off and make sure that the fan is working properly. It's possible that the fan motor is bad or the 3 pin fan header on the mobo is bad. 60C is a little too high.
  11. Jay H
    Jay H Producer
    Mar 22, 1999
    5,654
    32
    Pittsfield, MA
    Jay
    Hmmm, mine must be perpetually cold cause my t'bird 1gig CPU runs only at 31C and perhaps 46C at gamespeed (Wolf 3D) and I'm using the default AMD fan that came with it. I have a dual fan Enermax PS and the casefan in the front that came with the minitower too. I recently added an adjustable speed case fan in the back to suck air out and it dropped the casetemp by like a degree and is no louder than before.
    Jay
  12. Andrew Pratt
    Andrew Pratt Producer
    Dec 8, 1998
    3,806
    I'm at 44C at idle for my 1.33 athlon running at 1425mhz Case is at 34C
  13. BrianB
    BrianB Producer
    Apr 29, 2000
    5,205
    What sort of temperatures should I be getting with a Socket A Athlon 600? I'm sitting at about 32C, with a new Golden Orb fan that's definitely working.
  14. Jeff Kleist
    Dec 4, 1999
    11,267
    My monitor software is reporting 443F [​IMG]
  15. Rob Lutter
    Rob Lutter Producer
    Nov 3, 2000
    4,523
    well... my idle speed has gone down to 45 degrees celcius on the chip and 30 inside the case (gotta love aluminum) after installing Windows 2000... weird! (I have left it on for 3 days, so maybe the fan is getting worn in).
  16. Jeff Braddock
    Jan 26, 2002
    306
    An update....I popped the cover off comp. and the fan was not running. I fiddled around w/ the connection and it had somehow come loose. I checked the temp and it is still 52-53 C. This still seems a little high. Oh well I guess.
