How hot is your HK AVR-525?
Discussion in 'AV Receivers' started by Joe Ku, Jun 16, 2003.
  1. Joe Ku
    Joe Ku Stunt Coordinator
    Apr 1, 2003
    69
    I finally hooked up my AVR 525 last night. It is connected only to 8ohm Stereo speakers. I let it run at low volume last night to help break in the speakers and this morning I noticed it was very hot. It was uncomfortable to place my hand on top of the unit. It is in an open back case with about 6 inches of clearance above it, but almost none to the sides. Is this amount of heat normal? I an especially concerned with how hot it will get with all 7 channels running. I am going to move it to a position where it can get more air tonight, just curious how hot others get.
  2. Jason F.
    Jason F. Stunt Coordinator
    Mar 17, 2002
    153
    Joe I am currently in the market for a new receiver and the HK is one of my options. If you do a search on it you will see that alot of people have had the same thing with the HK, hope this helps.
  3. Rick Ewing
    Rick Ewing Agent
    Mar 20, 1999
    33
    I have one and yes, it does run on the warm side. The 70 wpc that HK advertises is "old school" power measurements. This receiver generates more juice than a number of its competitors, hence the heat issue.
  4. Joe Ku
    Apr 1, 2003
    69
    I feel better now, I love the way it sounds, I was hoping it was just the nature of the beast. I can crank it all the way up without a hint of distortion, I guess the higher Air conditioning bill is the tradeoff. I can live with that[​IMG] Thanks guys
