Ken Woodrow
- Feb 12, 2001
I did a quick search on this, but couldn't find anything definitive. I'm concerned about the potential for heat buildup in my A/V closet. It houses a DirecTiVo, a home theater PC, a Sony DB930 receiver, and -- watch out -- a LLano Trinity 200 watt/channel 3-channel amp. The closet is ventilated by an open register at the bottom and a small (8") fan at the top. I haven't measured the temp inside the closet with a thermometer, but you can feel some heat buildup when you open it up. BTW, I cut off the receiver and solid-state section of the amp, but leave on the HTPC and tube input stage of the amp 24/7. The closet fan also stays on 24/7. So far, nothing has fried.
But -- here are the questions:
1. What temp is potentially fatal for solid-state equipment?
2. Has anyone installed a thermometer that is linked to a fan?
3. If the fan is not sufficient, what else can I do?
ken
ken
