How hot does your reciever get?
Discussion in 'AV Receivers' started by Steve Jones, Jul 23, 2003.
  1. Steve Jones
    Steve Jones Extra
    Feb 22, 2003
    16
    I just bought a H/K AVR 525 and was curious how hot it should be. Obviously I don't want to blow it up! I have it in a cabinet with 3" clearance in the rear and 5" on the top. I leave the door open while it is on. It also smells when it is on. Not sure if it is normal electronics smell or maybe the polyurthane on the cabinet. Any help is appreciated.
  2. Yogi
    Yogi Screenwriter
    Jul 25, 2002
    1,741
    HK receivers run hot as they have poor heatsinking design. Give them plenty of room to breathe and you should be fine. I have a Technics SADX950 in the bedroom system and it runs so hot you could fry eggs on it. I installed a 2" parts express fan with a 12V adaptor plugged to the back of the receiver so everytime I turn on the receiver the fan comes on. The fan is very quiet and now my receiver runs cold.
  3. Mark Hedges
    Mark Hedges Second Unit
    Mar 21, 2003
    442
    My Sony DA4ES gets almost too hot to touch but only the area on top of the heatsinks and the transformer. The rest of it stays fairly cool as far as I can tell. It is in a cabinet with an open front and back, and about 3" of space on top. There isn't much room on the sides but IIRC there were no vent holes on the sides anyway.
    It gave off a smell when I first got it but doesn't anymore. I think it is just a "new electronics smell", somewhat akin to new car smell.
  4. Thomas Nichols
    Thomas Nichols Stunt Coordinator
    Nov 27, 1999
    115
    My H/K 125 does not even get warm to the touch. It is on a flex rack and is clear by 12 inches on all sides.
  5. Eric Moore
    Eric Moore Auditioning
    Jul 6, 2003
    7
    I have an H/K 525 and it gets hot. It also gives off that "electronic" smell. I have heard that H/K's tend to run hot so I am not too worried.
  6. Richard Travale
    Richard Travale Producer
    Feb 27, 2001
    3,425
    12
    The Island, Canada
    Rich Travale
    My Nakamichi doesn't get hot at all. Maybe a little warm after some marathon use but not much difference if just watching a movie.
  7. John Garcia
    Jun 24, 1999
    11,571
    25
    NorCal
    My Marantz 6200 never got very hot, even when driven very hard for a long period. I haven't had my new receiver long enough to know if it gets hot... My PM7000 integrated does not get more than warm to the touch ever.
  8. Michael R Price
    Michael R Price Screenwriter
    Jul 22, 2001
    1,591
    Don't be worried. Transistors and other electronic components are rated to work at temperatures of 85 degrees C (160 deg F or something) and higher. Some amplifiers are designed to operate at high temperatures, up to 55C which is hot enough that it hurts to touch for more than a couple seconds. Additionally, your receiver probably has a thermal switch to shut itself down if the temperature exceeds something like 75C in a fault condition.
  9. Kevinkall
    Kevinkall Second Unit
    Mar 20, 2003
    331
    My Kenwood 6070 gets a little warm after it's been on awhile, not as bad as some has mentioned.
  10. Steven Simon
    Steven Simon Producer
    Sep 14, 1998
    3,276
    7
    Steven Simon
    Steve,
    I also have the HK 525, and damn that thing get's hot. It virtually can heat up my room!!!
  11. Steve Jones
    Steve Jones Extra
    Feb 22, 2003
    16
    Thanks for all the responses. I think I will enjoy some movies at ease tonight.
  12. David Preston
    David Preston Supporting Actor
    Mar 23, 2003
    698
    I have a Marantz 7300 and it gets pretty hot. I want to help it out by cooling it with a fan.
  13. Joe Ku
    Joe Ku Stunt Coordinator
    Apr 1, 2003
    69
    My HK 525 also runs on the hot side. But I have never had any problems. Also, it is not a poor heatsink design just because it gets hot; it gets hot because the electronics generate a lot of heat. The purpose of a heatsink is to move the heat from the electronics to the outside of the unit, which it does quite well. But this unit definitely needs room to breath.
  14. Michael R Price
    Jul 22, 2001
    1,591
    I just think the receiver has plenty of protection for that sort of thing. They were designed to survive being abused.
  15. Yogi
    Yogi Screenwriter
    Jul 25, 2002
    1,741
    "Also, it is not a poor heatsink design just because it gets hot; it gets hot because the electronics generate a lot of heat. "
    Atleast when I looked inside the 520 I was shocked to see an aluminum foil bent in the shape of a heat sink. Now that was piss poor design for a receiver in that price range. I dont know about the 525 but hopefully HK redesigned the heat sinks to the standard extruded aluminum heatsinks found on most receivers and amps. In that case I stand corrected for my earlier comment.
  16. Jarvis_R
    Jarvis_R Agent
    Jul 7, 2003
    46
    I'm looking to get the H/K 525 next week. How much clearance would you guys suggest? My currents setup has about three inches on top with none on the sides and no back enclosure, but this is a lot bigger than my jvc.
    Any suggestions on where I should purchase from and/or price?
  17. Ben LG
    Ben LG Stunt Coordinator
    Jun 30, 2003
    225
    Also with my 6200, it runs very warm but never gets to the point where I would call it hot. In a related question to heat, I use my receiver daily switching it on and off multiple times a day (for instance watching the news, hbo at late night or dvds) so do you guys think it would be alright to leave it on most of the time with the occasional break? For convenience sake Im thinking more of like turning it off once a week or so or would that be a big no no?
  18. Steve Jones
    Steve Jones Extra
    Feb 22, 2003
    16
    I got mine at Etronics but 6Ave.com was alittle cheaper. I bought it from Etronics because they had another item I wanted the 6Ave didn't. I believe I paid $634 + shipping and 6ave was $619. It did arrive in 24 hours. Which was very nice.
  19. ChrisWiggles
    ChrisWiggles Producer
    Aug 19, 2002
    4,791
    Ben, I wouldn't worry too much about leaving your reciever on. Turn the volume down, and it will just stay slightly warm to the touch.
    That being said, my reciever is EXTREMELY hot. It's a marantz 5300, and I dunno bout you guys, but DAMN that unit is sexy! [​IMG]
  20. Joe Ku
    Apr 1, 2003
    69
    I would suggest at least an inch on each side and 6 inches above to keep the 525 cool. And the 525 does have an extruded aluminum heatsink. I would also have been annoyed with what you described in the 520.
