How High
Discussion in 'Home Theater Projects' started by Keith J, Sep 2, 2004.
  1. Keith J
    Keith J Stunt Coordinator
    Oct 3, 2001
    60
    I am constructing my theater now how high off of the floor should I mount my side and rear surrounds for 7.1.
    Thanx!
  2. BrianKR
    BrianKR Second Unit
    Oct 19, 2002
    498
    2' above ear level
  3. Jay Mitchosky
    Jay Mitchosky Producer
    Sep 6, 1998
    3,729
    As Brian mentioned the general rule of thumb is 2-3 feet above ear level. This measurement is to the tweeter, not the bottom of the cabinet as speaker dimensions vary. You should also avoid having the speaker too close to the ceiling/bulkhead so you may need to compromise based on your room. Also refer to your manufacturer's guidelines as they might have other indications for ideal location.
