How hardwood floors affect sound
Discussion in 'Archived Threads 2001-2004' started by Jason_H, Mar 3, 2002.
  1. Jason_H
    Jason_H Second Unit
    Mar 9, 2000
    422
    I just moved from a small carpeted apartment into a townhouse with hardwood floors. I get to play all media with higher volume, which is a great plus, but I have noticed that I seem to be getting a bit too much echo in my new room. I feel like I am losing too much fine detail due to the acoustics. Would getting a large rug for the floor between my speakers and couch help offset some of this? Any other opinions or suggestions?
  2. Bob_A
    Bob_A Supporting Actor
    Jul 30, 2000
    876
    A rug should help. Try it out. Good luck!
  3. GabrielC
    GabrielC Stunt Coordinator
    Nov 26, 2001
    101
    We just finished the basement in my house about 2 months ago, and for the first month it was bare hardwood floor.
    For about a week or so, I had an SVS 16-46CS on that floor and for some reason it didn't seem to produce as much of a kick as I thought it would.
    The next week we got our area rug laid down and it made quite a big difference, I could FEEL the sub now, and it took away the extra echoing.
    I think you may have a better experience once you get a carpet/rug on the floor!
    Mind you, throughout the entire time with the SVS, hardwood floor or rug, the floor above felt like it was alive and rolling [​IMG]
  4. John Desmond
    John Desmond Stunt Coordinator
    Nov 13, 2000
    90
    Get the thickest largest rug you can fit. It will make a major improvement.
  5. Jim Prillaman
    Jim Prillaman Stunt Coordinator
    Feb 12, 2002
    102
    Hardwood floor can be nice -- but it can also make the space too "hard." I ripped up the wall-to-wall carpet in my living room last May, and for a month or so had bare hardwood floor. I actually preferred the resulting sound over what I had with the carpet (despite some slight harshness that was similar to what you are noticing), but when I added a small (5'x8') area rug in front of the sofa it provided just enough softness to the room to eliminate the harshness that I hadn't been quite happy with.
  6. ChrisAG
    ChrisAG Supporting Actor
    Aug 26, 2001
    503
    Is it best that the speakers themselves be placed on top of the area rug, or should you just position the rug somewhere in front of them?
  7. John Desmond
    Nov 13, 2000
    90
    Chris, you might have to do a little trial and error here. However, you probably are going to want it pretty much centered between you and the speakers. If anything, you might need to pull it further toward you or under you.
