How good is the XBOX at playing DVD's?
Discussion in 'Archived Threads 2001-2004' started by Brian Kidd, Dec 3, 2002.
  1. Brian Kidd
    Brian Kidd Screenwriter
    Nov 14, 2000
    1,951
    259
    1,610
    Just the other day I purchased an XBOX. I already have a dvd player, but it's a pretty bare bones model. (Pioneer DV-333) How is the XBOX at playing dvds? Does it have zoom, slow motion, etc? I've thought about putting my Pioneer on another television and just using the XBOX as my primary dvd player. I just don't want to plunk down the extra $30 for the dvd remote (thanks for nothing, M$) if it's not worth it. Thanks.
  2. Andre F
    Andre F Screenwriter
    Dec 9, 2000
    1,486
    2
    I'd be interested to know as well...
  3. Dean Cooper
    Dean Cooper Supporting Actor
    Oct 23, 2000
    972
    3
    I find that it is an above average player for low end. It has an up to 10X zoom and slow motion. The on screen menu is a bit anoying but functions well. One thing that I have found is that it handles a layer change very well. It's worth picking up.
    Dean
  4. Steve Clark
    Steve Clark Second Unit
    Nov 26, 2001
    283
    Yea, Brian, I am in the same predicament. I just bought an XBox on Friday and would like to incorporate it into my main Home Theatre system in the living room. If I do this, I would like to replace my older, 3 year old Toshiba DVD player (SD-1200) with the XBox. The Toshiba has been flawless to date, except for the bug where straight lines appear jagged. Can we assume the player would be on par with the older, lower end Toshiba, Pioneer and Sony players and superior to the new cheap players, i.e. Apex, Mintek?
  5. Oscar Saenz
    Oscar Saenz Stunt Coordinator
    Sep 23, 1999
    187
    My XBox has served as "backup" to my Pioneer Elite DV-37 on at least a couple of occasions. For some reason my progressive scan Pioneer player could never play the Dinosaur and Moulin Rouge DVDs but, the XBox always played them flawlessly. And now, the same thing has happened with the new Goldmember DVD. My DV-37 has problems with it while my XBox plays it like a champ.
    However, I must note that the video quality is definitely noticeable between the two players but, not enough to call the XBox a bad player.
  6. Dave F
    Dave F Cinematographer
    May 15, 1999
    2,885
    2
  7. Brian Kidd
    Nov 14, 2000
    1,951
    259
    1,610
    I'm just curious as to why that is, Dave? Is the Daewoo that great or is it that it can be modified to multi-region so that's why you prefer it.
    Oscar-- I can understand that it wouldn't compare to your Elite player. I just have an entry-level Pioneer, though. Is it at least comparable to that?
  8. Dave Sabo
    Dave Sabo Stunt Coordinator
    Sep 23, 2002
    144
    Well, being relatively new to the entire Home Theater thing, my Xbox is my only DVD player at the moment. Does a fine job for me, works with my universal remote just fine.
    I'd say the only down side is that it's pretty loud, I mean the fan/idle noise is a bit loud. But I just turn the volume up [​IMG]
  9. Travis Olson
    Travis Olson Supporting Actor
    Oct 7, 2001
    937
    Travis Olson
    I think the X-Box makes a very good stand alone player if it's all you can afford at the moment. I find that it does not have the picture quality of my main player (JVC XV-SA75), but it is definitely better then most 1st generation or sub-$100 decks. The layer change is incredibility fast as well, you can't even notice it.
  10. Brian Kidd
    Nov 14, 2000
    1,951
    259
    1,610
    Well, I think for now I'll keep it as a game machine. Maybe down the road I'll spring for the extra remote once knock-offs become available. I still say that it should work out of the box. The remote thing is a sham.
  11. Joe Szott
    Joe Szott Screenwriter
    Feb 22, 2002
    1,962
    Brian -- The reason they do that is because Sony owns the rights to the DVD format. For Sony to put DVD playback in PS2 consoles is free, MS has to pay Sony like $5-15 bucks per console for the privaledge. So MS sells a DVD remote unit that costs $2 to make plus the $15 to Sony for $20, they make a whopping $3 on each one. If people don't buy the remote, then MS doesn't have to give Sony any money when an Xbox sells.
    Does anyone know if the Xbox plays VCDs and SVCDs? How well does it do this if it does?
  12. Brian Kidd
    Nov 14, 2000
    1,951
    259
    1,610
    I did not know that. Interesting outlook. They actually sell the remotes for $30, though. A little more than $3 profit. Still. Makes more sense to me now.
    As for VCD's? Apparently won't play them. Another reason I think I'll keep my Pioneer.
  13. Dave Sabo
    Sep 23, 2002
    144
    As Brian said, no VCD's... and it's finicky with cd-r's as well.
    On a side note - A great place to see the compatibilities of formats for any dvd player or game system... check out the lists at www.vcdhelp.com
  14. Scott Van Dyke
    Scott Van Dyke Supporting Actor
    Jan 21, 2002
    579
    I don't like the zoom feature on the Xbox. Seems like you zoom it once, and boom!- It's too far zoomed in. Then you can't scroll around the picture either. At least not with mine...
    For my first DVD player, I enjoy it! I actually play more DVD's than games.
  15. Brian W. Ralston
    Brian W. Ralston Supporting Actor
    Apr 4, 1999
    604
    Los Angeles, CA
    Brian W. Ralston
    See if you can get someone from another DVD region to buy the XBOX DVD remote there and ship it to you. Since the XBOX gets its region code setup by the IR dongle you plug into the front on the first use of the remote...you can get a region 2 DVD player (or another region), simply by using a XBOX DVD remote from another region. I believe this will lock in the region on the player though so once you use it, it will be that region forever.
    Just a thought is you decide not to use it for a regular DVD player, but would like to have another region encoded player for about $30.
  16. Brian Kidd
    Nov 14, 2000
    1,951
    259
    1,610
    Hmmmmmm. Brian, you naughty boy. Tempting, tho.
  17. Adam Tyner
    Adam Tyner Screenwriter
    Sep 29, 2000
    1,410
    Brian - if I snag an R2/R4 remote, will the XBox do PAL->NTSC conversion?
  18. Jeff Kleist
    Dec 4, 1999
    11,267
  19. Dave Falasco
    Dave Falasco Screenwriter
    Oct 2, 2000
    1,185
    What?!?! It will?!? [​IMG]
    Wow, I didn't realize that. Interesting...most interesting...hello, Japan? Yes, I'd like to place an order...
    [​IMG]
  20. Jeff Kleist
    Dec 4, 1999
    11,267
    Japan is not PAL, it's NTSC
    You can buy Japanese DVD kits from www.ncsx.com
    Just remember once you plug in a dongle, it's that code FOREVER.
