Mandy_P
- Dec 2, 2003
Hello Everyone,
I have been trying to decide on a sub for the last couple of weeks. I had finally decided on the SVS PC+, that was until I came across the av12 and the preorder. I broke down and ordered two, but the question is; now what? I've done some diy in the past. I have a DPL12 in a 16" sealed cube powered by a Tripath amp that was home brewed. Although it does add some level of sound for music it breaks down when asked to do HT at moderate levels. I realize the box is too small but it's what I had to work with given the space limitations. Would replacing the DPL with the av12 work better in such a small box?
How good is the av12 compared to the svs? I was thinking of building a 3 cu ft. enclosures with the 15" 1400 PR. I'm also picking up the BFD this week. Amplification is still up in the air. I've considered using the Tripath again or buying the Samson S1000 or the Rythmic. After everyting is said and done I'll probably have a couple of dollars left over in comparison to buying the SVS. Is it worth it? Any comments or suggestions are welcomed.
TIA
TIA
