How good do DVD-R copies look on big screen (plasma) t.v.?
Discussion in 'Archived Threads 2001-2004' started by Dick, Feb 8, 2003.
  1. Dick
    Dick Lead Actor
    May 22, 1999
    6,587
    2,657
    9,110
    Maine
    Rick
    How do copies made from satellite broadcasts to DVD-R discs from, say, TCM, look when shown on screens of 50" or more? I'm talking about self-made copies using a Panasonic DMR or a Phillips DVD recorder at standard play speed (2 hours).
  2. Jack Briggs
    Jun 3, 1999
    16,738
    129
    The copies should look as good as the original broadcast, provided everything's working as it should.
  3. Eric-S
    Eric-S Stunt Coordinator
    Jan 3, 2000
    213
    They should look very good. The DVD recorder does have to re-encode the analog signal, so there may be some digital artifacts if you look close enough. Even at the XP speed, (1 hour) I find some artifacts around some text that were not in the source. (I use the DMR-HS2)
    But to put it all in perspective, the XP and SP modes look great! I can't think of a better recording medium for home use.
    Eric
  4. Dick
    Dick Lead Actor
    May 22, 1999
    6,587
    2,657
    9,110
    Maine
    Rick
    What I find is that, when people and objects are motionless, I get a crystal-sharp image and, indeed, it does look as good as the original. However, when the camera pans vertically or horizontally, or theere is other motion on screen, I lose edge definition - a sort of soft blur effect. Is there no way to eliminate or minimize this?
  5. Michael St. Clair
    May 3, 1999
    6,001
    I've done a bit of this.
    It depends on the source. If the source is noisy, or full of artifacts due to overcompression, even XP (1-hour) mode can look notably worse than the broadcast.
    If the source is extremely clean, SP (2-hour) mode can look very close to the broadcast, and XP may be nearly indistingishable from the original broadcast.
    Of course, it partially depends on how critical of an eye you have...we are not all the same.
