How far should I sit from my TV
Discussion in 'Archived Threads 2001-2004' started by Richard Cook, Mar 23, 2001.
  1. Richard Cook
    Richard Cook Stunt Coordinator
    Aug 12, 1999
    88
    I'm just about to take delivery of a 42" 16:9 TV to replace my 29" 4:3 model.
    My question is: How far should I besitting from the new set in order to achieve the best impact? I belive there is a formula to work this out but I can't remember what it is.
    I'm currently sittin 6'(2 metres) from my current TV.
    Many thanks in advance.
    Richard (UK)
  2. Steve Tannehill
    Steve Tannehill Ambassador
    Jul 6, 1997
    5,547
    215
    DFW
    Steve Tannehill
    IMO, it's a matter of personal preference.
    - Steve
  3. Dan Hitchman
    Dan Hitchman Cinematographer
    Jun 11, 1999
    2,713
    Yes, there is a formula. I believe one such formula was discussed in the Joe Kane special video edition of Widescreen Review. It has to do with angle of view, site lines, and whether or not you'll see scan lines on the screen.
    Things have changed a bit with HDTV so you can sit closer than with the NTSC system without seeing scan lines, pixel structure, etc.
    However, I believe there is a SMPTE approved rule of thumb as to the proper calculations for both 4x3 and 16x9 screen ratios.
    If I run across them, I'll post them here.
    Dan
    Boycott JVC, 5C, HDCP, DFAST, and stop the MPAA!! Call Or Write The FCC And Your State and Federal Representatives To Protect Quality HDTV And Other HD Media, And Your Constitutional Rights!
  4. Aaron Plaza
    Aaron Plaza Auditioning
    Feb 12, 2001
    11
    Yeah I remember reading about a formula. But do you think I could find it in all my magazines. I do recall a general rule of thumb that you want the field of view to be no greater than 30 degrees.
  5. Wayne Bundrick
    Wayne Bundrick Cinematographer
    May 17, 1999
    2,358
    I could be wrong but I thought it was 7 screen heights for NTSC resolution and 3 screen heights for HDTV resolution.
