How far should I seperate the surround rear speakers in a 7.1 setup?
Discussion in 'Speakers & Subwoofers' started by Todd smith, Jul 30, 2004.
  1. Todd smith
    Todd smith Supporting Actor
    Apr 2, 2002
    643
    How far on the back wall of my theater should these two speakers be seperated?
  2. StephenHa
    StephenHa Second Unit
    Sep 28, 2003
    364
    how big is the room, how far are you from the rear speakers? I've seen a few recomendations the rear speakers should go on the side wall in the rear, I play with placement and see what sounds best to me usually
  3. Dennis Gardner
    Dennis Gardner Stunt Coordinator
    Dec 12, 2002
    206
    If they are direct speakers, in the corners toed in towards the sweet spot works great for me. If you must mount them on the rear wall, both placed 1/3 the way in from the corner works good. Some put them directly opposite their mains.
    Both of these assume you are a good distance from the rear wall, if your seating is close to the rear wall, then angled down to your seating works good.
    Here is Dolby's suggestions:Dolby HT Setup
  4. Jack Shappa
    Jack Shappa Second Unit
    Jan 24, 2003
    411
    Mine are on the rear wall (thus the name REAR speakers!)about 1/3rd of the way in from the sides (they end up about 4 feet apart). Firing directly over the viewers' heads (1 foot over the back row, 2 feet over the front). This is pretty standard, but of course your room dicates what sounds best
    - Cryo
  5. Gabriel_Lam
    Gabriel_Lam Screenwriter
    Mar 7, 2002
    1,402
    From Dolby:
    [​IMG]
  6. Kevin C Brown
    Kevin C Brown Producer
    Aug 3, 2000
    5,712
    I like the idea of an equilateral triangle back there. For example, my rears are 5 ft each from me, and 5 ft from each other.
    A wise man once answered this question thusly:
    Start with the rears side by side. Play discrete test tones. Move them apart until you can just differentiate the test tone from the left rear speaker from the right rear speaker.
    (Courtesy Sanjay Durani! [​IMG] )
    But if you look at the recommendations for THX Ultra2, they actually include side--by-side placement too.
