How does this setup look?
Discussion in 'Archived Threads 2001-2004' started by Whitney B., Nov 11, 2002.
  1. Whitney B.
    Whitney B. Auditioning
    Sep 15, 2002
    13
    A friend of mine has finally got rid of his Bose system and has decided to spend $800 on a new system. This is what I've come up with so far.
    Reciever
    Pioneer VSX-D711
    Pioneer VSX-D511
    Denon 1603
    Speakers
    Center: JBL S Center II or JBL N Center II
    Main: JBL N38II or JBL N28
    Rear: JBL N28
    Subwoofer
    Sony SA-WM40 Subwoofer
    I like the S Center over the N Center but will there be a problem with timbre matching?
    He already has a decent dvd player.
    His listening habits are about 90% movies.
  2. Will Orth
    Will Orth Stunt Coordinator
    Sep 14, 2002
    80
    I use the Jbl N26's for the rear only as i like there live sound but would not use the others for the mains.
    Reason is Front stage Quality.
    Will
  3. John Garcia
    Jun 24, 1999
    11,571
    25
    NorCal
    Timbre between the fronts should be matched perfectly. Though the N and S series will probably be an acceptable blend, with S-center, I would highly recommend your mains be Studio series also. Ns for rears with Ss as mains is fine.
  4. Alf S
    Alf S Producer
    Apr 23, 2000
    3,114
    532
    4,110
    Alfer
    Looks good so far.
    If he can squeeze out a few pennies more (or actually it may still fit the budget) he may want to get the Pioneer 811. It's a great receiver and if he had any other future upgrades down the road, this receiver can fit the bill.
    Alfer
