how does standard tivo record a hi-def show? (1 Viewer)
Ted Lee
somebody asked me, but i wasn't sure.
so, if i have a regular external tivo box, and i'm watching a hi-def show, does the tivo just record it at standard definition quality?
or can it even record it at all?
Stephen Tu
Whatever HDTV receiver you are using would have to have a downconverted, NTSC output, which the Tivo would record as usual. Some of them can't output HD & NTSC at the same time, unfortunately.
linda19798888
