How Does Shuffle on a DVD/CD Player Work.
Discussion in 'Playback Devices' started by Don, Jan 3, 2004.
  1. Don
    Don Second Unit
    Jun 30, 1997
    374
    ok i have a CD that says i can hit shuffle after i put two cds in and it will give it a one of a kind sound etc. anyone know how this works and any certain models or brands with this option. Don,
  2. dave_brogli
    dave_brogli Screenwriter
    Mar 30, 2002
    1,021
    doesnt it just "shuffle" the cd's while playing......
    disc 1 track 4
    disc 2 track 9
    disc 1 track 7
    disc 3 track 13
    etc etc.....
    right?
  3. Don
    Don Second Unit
    Jun 30, 1997
    374
    i'm not sure how it is supposed to work or operate that is why i'm asking. i'll post the instructions i have for the cd later. Don,
  4. ChrisWiggles
    ChrisWiggles Producer
    Aug 19, 2002
    4,791
    I don't understand your question. A multi-disk player may have a shuffle option for one or all discs, and it just plays tracks randomly from one or all the CDs.
    There's no sound difference or anything.
  5. Jason_A
    Jason_A Stunt Coordinator
    Jun 25, 2001
    94
    Chris is right and any dvd/cd player has this feature.
  6. Don
    Don Second Unit
    Jun 30, 1997
    374
    ok here goes the instruction on the CD Case. create your own party mix ! put both discs in the cd player and hit "shuffle" and you've got a great mix of awesome halloween music and incredible sound effects. now would this mean you need more then one CD tray holder to do this or do you just stack one on top of each other. Don,
  7. jeff peterson
    jeff peterson Supporting Actor
    Nov 29, 1998
    675
    Don, you need a CD player that holds more than one disc. You can't stack them on top of one another. If your player only holds one CD, you can only shuffle the tracks on that one CD.
    As an example, my CD player holds 5 CDs; so I can put in up to 5 and shuffle the tracks among them all. That CD you have is assuming you have a multi-disc player.
  8. Jason.Soko
    Jason.Soko Stunt Coordinator
    May 30, 2003
    219
    [​IMG]
