How does Center channel decoding work?
Discussion in 'Archived Threads 2001-2004' started by Aaron_Morris, Dec 14, 2002.
  1. Aaron_Morris
    Aaron_Morris Stunt Coordinator
    Jul 1, 2002
    106
    Appologize if this should have been posted somewhere else...
    How does center channel decoding work when the input is stereo? I am fairly sure that it isn't just a sum of L and R otherwise it would have L only sound in it. Does anyone know how something like Pro Logic combines the left and right channels common sounds for a center? Thanks in advance for any insight.
  2. Patrick Sun
    Patrick Sun Moderator
    Jun 30, 1999
    38,749
    480
    9,110
    DPL steers the common in-phase Left and Right signals into the Center channel, and steers the Left-only signal into the left channel, and the same with the right channel. DPL also steers the not-in-phase left and right signals for the back channel.
  3. Aaron_Morris
    Jul 1, 2002
    106
    Thank you sir. I suppose DPL is not the only form, right? Is there another way that another group has come up with? Non-Dolby?
  4. Wayne A. Pflughaupt
    Aug 5, 1999
    6,123
    40
    6,610
    Katy, TX
    Wayne
  5. Patrick Sun
    Jun 30, 1999
    38,749
    480
    9,110
    Doesn't the Neo dts/cirrus processing and the Logic 7 processing do the same sort of processing of 2-channel sources?
  6. Yee-Ming
    Yee-Ming Producer
    Apr 4, 2002
    4,375
    16
    610
    "on a little street in Singapore"
    Yee Ming Lim
    or for that matter Circle Surround 5.1?
