How do you zoom in the viewpoint in SSX Tricky PS2?
Discussion in 'Archived Threads 2001-2004' started by Kelly Scott Rickards, Dec 31, 2001.
  1. Kelly Scott Rickards
    Kelly Scott Rickards Stunt Coordinator
    Jan 26, 2000
    225
    In the original version of SSX, you simply press a single button (triangle, I believe) to toggle the 3 or 4 different views...
    I read the manual for tricky and I think it says to switch to advanced or "pro" controls to change the viewpoint...
    Then it says you can change the viewpoints by holding L1+ the D pad or L1 + left stick....
    Tried it and it doesnt work (GAWD EA, would it have really killed you use the triangle to zoom?)
    HELP!!!!
  2. Rob Speicher
    Rob Speicher Supporting Actor
    Nov 24, 2000
    935
    You do have to change the control scheme to Pro, and then it works.
  3. Steven_V
    Steven_V Stunt Coordinator
    Mar 10, 2001
    182
    Pause the game, go into 'options', and you can change the camera view.
  4. Kelly Scott Rickards
    Jan 26, 2000
    225
    Yeah, I figured the pause game trick..
    Boy do I feel STOOOPID!! [​IMG]
