How do you use Dayton gold banana plugs?
Discussion in 'Archived Threads 2001-2004' started by Allen Longcor, Dec 2, 2001.
  1. Allen Longcor
    Allen Longcor Supporting Actor
    Oct 21, 2001
    546
    These were recommended to me and so I bought some for my 12 gauge speaker wire. They are the screw set type. Can someone tell me how to use them? Do I put the speaker wire in, pull it partway out through one of the holes at the top of it, and then put that little metal pellet type thing back in and screw the bottom back on? Here is a link to the type I got: http://www.partsexpress.com/pe/pshow...091-1165&Did=7
    If anyone can help that would be great. It doesn't show the holes on either side that are at the top in the picture though.
  2. MarkS
    MarkS Agent
    Oct 30, 1999
    33
    These look alot like the AR banana plugs I currently have (which I hate BTW).
    They are actually two pieces. The wire comes through the bottom piece which is essentially a gold plated metal tube. You cut back to the bare speaker wire about 1/4" to 1/2". The wire is then "frayed" around the top of this tube and the top piece screws down over the top of it. Obviously you have to make sure that no extra bare wire is showing after you screw it down.
    The issue I have with these are that the surface area which the plug is in contact with the speaker wire...well there is not that much contact.
    I am upgrading mine to a better set-screw style which will have better surface contact (my friend Brett D. may tell you that these are not "sealed", but that's a different thread):
    KnuKonceptz Banana Plugs
  3. MarkS
    MarkS Agent
    Oct 30, 1999
    33
    There is always one in the forum...
    Brett I am actually still considering your offer on speaker cables. I would prefer to use better cable than SoundKing (no argument it is a bargain) and better connectors than Radio Scrap, I mean Shack.
    I still am warm on the 8 or 10-gauge KnuKonceptz cables and I do not know what the next step up is for gold-plated crimp style bananas...I would be willing to pay the diff for the upgrades.
    What do you say?
    -mbs
  4. Brett DiMichele
    Brett DiMichele Producer
    Sep 30, 2001
    3,181
    Mark,
    I honestly beleive that using the Knu Concepts wire over
    the SK wire will net you no gain but if you want me to
    make you a set of wires with the Knu 10awg I certainly
    could do that. As for termination options. Aside from
    RS Banana's or something from Partsexpress you don't
    have many other options without drasticly increasing
    the price.
    I could make you the cables with WBT connectors but
    then the prices I quoted you via email wouldn't even
    pay for the WBT's (which are $80.00 per 4!)
    I betcha I could solder the KNU wire onto the KNU Banana's
    without a problem..
    It's up to you... You can save some money if you do them
    yourself. Do you have the equipment to solder? Shoot me
    an email we can talk more in depth that way.
  5. JohnMW
    JohnMW Second Unit
    Dec 1, 2000
    280
  6. Brian Schucher
    Brian Schucher Supporting Actor
    Nov 22, 2000
    700
  7. Brian Schucher
    Nov 22, 2000
    700
    LOL. ya beat me by a minute....
  8. Steve Gazi
    Steve Gazi Stunt Coordinator
    Sep 24, 1999
    80
    I need to order some connectors. I only need these for the L, R and C channels, right? From the looks of the VR-507 receiver I'm getting the two rear surrounds use those spring-loaded connectors.
  9. Allen Longcor
    Oct 21, 2001
    546
    I already have the banana plugs, but want to make sure that I connect them the right way. They don't come with instructions of any type.
  10. Vince Bray
    Vince Bray Stunt Coordinator
    Oct 4, 2000
    170
    Allen,
    the plugs they linked you to are different, and imo, excellent. I simply clamp the wire (no screwdriver needed) and then use clear heat shrink to make sure none short. These are a great bargain, and are bullet-proof!
    Vince
  11. Quentin
    Quentin Cinematographer
    Feb 4, 2002
    2,670
    101
    Los Angeles
    Quentin H
    I'm resurrecting this thread because no one ever answered the question on how to connect these banana plugs...they only suggested easier ones!
    Well, I don't have the easier ones. I have these: http://www.partsexpress.com/pe/pshow...091-1165&Did=7
    They are in two parts: The sleeve and the plug piece that screws into the sleeve. The plug piece actually has two very small holes with miniature screws in them (that I presume are unscrewed and then screwed back in at some point to crimp/hold the speaker wire?).
    Honestly, I'm stumped. Does the wire go into the back hole of the plug and gets held down by the two crimp screws? Why are there two screws/holes at different points of the plug body? Does the wire go into one of these miniature holes? Out of one? Does the sleeve do anything but hold the plug part? I guess not...which means no wire contact with the sleeve (which I guess doesn't matter since the sleeve does not plug into anything.
    Any help? Anyone figure these out? I'm not sending them back to partsexpress. I just want to figure these out.
    Thanks-
  12. Earl Simpson
    Earl Simpson Supporting Actor
    Jan 12, 2002
    803
    The ones I bought(8 awg 091-1260) Are so large you can put the wire through the back or side. They are designed to stick the wire through the side and screw down on the wire. But you could take a 12/or 10 awg and put it in the stack on hole in the threaded top machined screw, bend the wire with a short 90 at the end and then tighten it down on the wire. This might work better for some rcvrs which do not have much side to side space. I just figured that out as a possibility. I will probably do it that way, since I prefer my wires sticking straight out the back(unlimited rear space behind the rcvr).
    PS/ these are gold plated and built very well
  13. Quentin
    Feb 4, 2002
    2,670
    101
    Los Angeles
    Quentin H
    bump...still wondering [​IMG]
  14. Earl Simpson
    Jan 12, 2002
    803
    Get the ones in my post. Several of us have. That part number that you linked does not give a wire size for the plug. You can call parts express and ask them if it will take 12awg and how it screws down. I'm sure you unscrew the top and stick the wire in zee hole and crank it down. I don't like that method. But hey, it might work for you. Go for it![​IMG]
