How do you remove wrinkles from a vinyl screen
Discussion in 'Beginners, General Questions' started by Stephen Dale, Jun 27, 2004.
  1. Stephen Dale
    Stephen Dale Auditioning
    May 20, 2004
    2
    Hello,
    Does anyone know how to accomplish this. The material is back on its frame after a couple of weeks being rolled up during some remodeling. I'm hoping that time will do the trick, but if someones ever overcome this problem, any tips on removing wrinkles would be greatly appreciated. Thx...
  2. StephenHa
    StephenHa Second Unit
    Sep 28, 2003
    364
    apply a little heat from a hair dryer (works on seat covers) I've never tried it (never had problems with wrinkles guess I'm lucky)
  3. Frank Zimkas
    Frank Zimkas Supporting Actor
    Mar 10, 2002
    888
    If your talking about a screen made out of black out liner, I stretched mine over the frame and used a steam iron held off the material about 1/2". I used a lots of steam and it relaxed the creases nicely and didn't harm the material at all.
  4. Cees Alons
    Cees Alons Moderator
    Jul 31, 1997
    19,475
    340
    9,110
    Cees Alons
    Stephen,
    Welcome to the forum!
    How bad is it? Do you know the manufacturer of the screen? If you do, and if it's relatively bad, I would contact them for advice if I were you.
    Cees
