How do you remove Diamond Shield "clips"?
Discussion in 'Displays' started by douglas-b, Jan 9, 2004.
  1. douglas-b
    douglas-b Stunt Coordinator
    Dec 4, 2003
    196
    Indiana
    Douglas Berry
    I can't seem to remove the clips on my Mit's 55413. I really want to see what the picture looks like without it. Where do I hold...what direction do I pull?
  2. Aaron Silverman
    Aaron Silverman Executive Producer
    Jan 22, 1999
    11,238
    787
    9,110
    Florida
    Aaron Silverman
    I have the same problem with my 55513! The manual has a diagram, but it doesn't seem to match the actual TV. And I'm afraid to try forcing it.
  3. Dennis Heller
    Dennis Heller Second Unit
    Nov 29, 2001
    288
    On my 48313, in the top right corner of the screen, I put a plastic pencil (with the point retracted) in the groove between the clip and the frame and pushed toward the left. It took a bit of pressure. Once I got the corner out, the rest came out easily. I then went to the top left corner and pushed to the right. Be sure to use something that won't scratch the screen. Hope that makes sense.
  4. Hugo
    Hugo Stunt Coordinator
    Nov 21, 2002
    147
    Hi, it's better if you use a small piece of plastic, like a credit card or an ID, and place it between the DS clip and the DS, then pull towards you (away from TV).
  5. douglas-b
    Dec 4, 2003
    196
    Indiana
    Douglas Berry
    I tried until my fingers were sore I just don't get it...they just won't come out!
  6. douglas-b
    Dec 4, 2003
    196
    Indiana
    Douglas Berry
    Can someone post a picture to show me???
  7. Ralph Summa
    Ralph Summa Supporting Actor
    Nov 6, 2001
    715
    Gregg Loewen removed the Diamond Shield from my Mits 55807 using an ordinary putty knife.
  8. Aaron Silverman
    Jan 22, 1999
    11,238
    787
    9,110
    Florida
    Aaron Silverman
    I'll have a chance to ask Gregg in a few weeks. [​IMG]
  9. Gregg Loewen
    Gregg Loewen Video Standards Instructor, THX Ltd.
    Insider
    Nov 9, 1999
    6,374
    32
    6,610
    New England
    Gregg Loewen
    Ralph,
    It wasnt an ordinary putty knife, it was an ISF certified putty knife! :)
    Dont use a pencil, use something that will spread out the force evenly.
    Best wishes
    Gregg
  10. Eric Hahn
    Eric Hahn Agent
    Jan 12, 2004
    49
    check out the "spot" thay have a thread just like this one with a pic, they suggest using a credit card to loosen the clips enough to grab with your fingers??
  11. Ralph Summa
    Nov 6, 2001
    715
    Now THAT'S why you have your TV professionally calibrated!
    [​IMG]
