How do you guys secure the speakers onto stands?
Discussion in 'Archived Threads 2001-2004' started by Antonio, Apr 10, 2002.
  1. Antonio
    Antonio Extra
    Mar 16, 2002
    22
    I have a pair of Paradigm Atoms as my surrounds and a set of Sanus 300 stands. All I have to do is figure out a way to secure the speakers onto the stands so they don't slip or get bumped off or something like that. I don't think anyone drills holes into their speakers so do you guys use velcro stickers or something? All ideas are usual welcome.
    ~Antonio
  2. Joe Tilley
    Joe Tilley Supporting Actor
    Jan 1, 2002
    686
    Antonio,something that will work very well is double sided foam tape,if you have a local automotive paint supplier in your area you can get it in various sizes fairley cheep and this stuff will hold just about anything,just make sure the surface dosent have any polish or anything like that on it first. You can find the same type of stuff at just about any store but the automotive grade stuff is much stronger and will come off in one peice if needed.
    In fact I can give you a part # its made by 3M its called Scotch-Mount part#051131 it is a 1/2 in wide by 5 yd roll hope this helps out.[​IMG]
  3. MarkO
    MarkO Second Unit
    Feb 19, 1999
    309
  4. AaronMg
    AaronMg Stunt Coordinator
    Mar 20, 2002
    247
    ^ ^ I use that stuff, its great! You can actually pick up the speaker without the stand falling off. If you go to your local HT store, they might give you a few pieces for free.
  5. Walt N
    Walt N Second Unit
    Jul 23, 2001
    417
    This stuff from Office Depot is virtually identical to Blue-Tack at 1/10th the price. Works great for sticking speakers to stands. Very secure bond yet removes without a trace.
  6. MarkO
    MarkO Second Unit
    Feb 19, 1999
    309
    Blu-tac in retail stores is about 4 dollars. AA is just asking a premium for it. I found a yellow variant for about the same price at Home Depot.
  7. Bob U
    Bob U Stunt Coordinator
    Oct 6, 2001
    137
    Just a caveat on Blue Tack. I had to move my speakers this weekend after six years on their stands - needed more room for my SVS subs that are coming. One speaker released fairly well from the stand withthe help of a friend. The Blue Tack on the speaker near the window actually took the paint and a little wood with it. Seems that the extra sun and heat had really hardened it.
    When I try to remove it in the future, i will try a hair dryer to see if warming it will make it easier to remove the speaker from the stand with no damage.
    -=Bob=-
  8. BruZZi
    BruZZi Second Unit
    Nov 1, 1999
    327
  9. Rick Guynn
    Rick Guynn Second Unit
    Mar 23, 1999
    473
    My speakers (Audax HT series) weigh about 45lbs a peice, they will not move from their stands [​IMG]
    Rick
  10. John Royster
    John Royster Screenwriter
    Oct 14, 2001
    1,088
    screws.
    'dem son-of-a-guns ain't goin' no'er.
    seriously.
  11. Jeff D.
    Jeff D. Supporting Actor
    Jul 10, 1999
    521
    Another sure-fire vote for Blu-Tak or Fun-Tak. No need to look any further than this.
    /Jeff
  12. John Garcia
    Jun 24, 1999
    11,571
    24
    NorCal
    I like blu-tac and it's variants, but as noted, over time and temp, it can harden. I prefer a thin, double sided foam tape, which can be found at any hardware store for around $1-$2.
  13. SHAWN SZILEZY
    SHAWN SZILEZY Stunt Coordinator
    Jan 4, 1999
    136
    My Atlantic Tech's actually have threaded inserts to which I installed screws into through my speaker stands. Works great...very solid.
  14. Phil Iturralde
    Phil Iturralde Screenwriter
    Oct 7, 1998
    1,867
    1) I used 1" wide velcro on the bottom of JBL N24's and 5" x 5" top plate of my 31" Sanus Basic Foundation Speaker Stand.
    2) Nothing except the supplied 4 triangle rubber adhesive speaker pads supplied w/my 16" Sanus Basic Foundation Speaker Stand 7" x 7" top plate and JBL S26 (22 lbs).
    Soon to be replaced with an 18" Tri-Pillar MDF Black Speaker Stands
    [​IMG]
    that I won @ eBay for $16.50. I'll probably use the supplied Speaker cushions on the Top Platform (1/2" thick and measures 6-1/2" x 6-3/4").
    Phil
  15. Antonio
    Antonio Extra
    Mar 16, 2002
    22
    Thanks guys for the suggestions!
