How do you connect DVC 15" to PE 250? (1 Viewer)
Jedd
I just put my tube, driver and amp together and found one good and one bad thing.
good one: cables from the amp are long enough to reach the driver
bad one: the "amp connectors" doesn't fit into the driver's terminal
So, what would you recommend, cut the connectors off and stick naked amp wires into the terminal or somehow solder/plug them to the cables paralleling terminals on the driver? (like remove isolation from the paralleling cable somewhere in the middle and stick amp cable to that place)
Any other ways around?
Brian Bunge
Jedd,
Just cut the ends off the speaker wires and strip back 1/4-1/2" and stick in the spring loaded terminals.
Brian
Jedd
Does terminals on the amp wires have any value, or I should strip them as well?
(I thought that there are some sort of specials connect-tweaks for them)
Brian Bunge
Jedd,
That's exactly what I was talking about cutting off. Cut off the push on terminals on the ends of the wires coming off the amp and strip the ends off. Since the driver has spring loaded terminals you just need to stick the stripped wire ends in there.
Brian
superbolix
