How do you break in a new car?
Discussion in 'Archived Threads 2001-2004' started by Ted Lee, Aug 12, 2002.
  1. Ted Lee
    Ted Lee Lead Actor
    May 8, 2001
    8,390
    hi all -
    what is your technique...or what have you heard?
    i've been told you should really try to wear the engine at all rpm's (high and low). that will prevent the new engine from "grooving" into one particular range, allowing the engine to break in at all points along the "curve".
    also, i hear you should do mostly city driving, with lots of starts and stops? if you have to do freeway driving try to vary the speed? i assume this also has to do with varying the rpms?
    break in occurs at approx 500 miles?
    any thoughts welcome...
    ted
  2. Josh Lowe
    Josh Lowe Screenwriter
    Jun 19, 2002
    1,063
    that stuff doesn't really matter any more. rings seat pretty much as soon as the motor is first turned over at the factory.
  3. Brian Kleinke
    Brian Kleinke Supporting Actor
    Sep 9, 1999
    974
  4. Todd Hochard
    Todd Hochard Cinematographer
    Jan 24, 1999
    2,312
    Varying RPMs is an OK idea, but don't feel obligated to run the engine at 5000+ rpm under light load. A recipe for disaster. If you wish to take a road trip, then occasionally drop back one gear from the top, hold for a minute, then return.
    My break-in rule is no full-power blasts for the first 1000 miles.
    Todd
  5. Brian Harnish
    Brian Harnish Screenwriter
    Dec 15, 2000
    1,216
    I personally prefer a big rock through the back window but that's just me. [​IMG]
  6. Ted Lee
    Ted Lee Lead Actor
    May 8, 2001
    8,390
    [​IMG]
    okay, clearly this is a good example of "think-before-you-title-your-post"
    hmm! thanks all...pretty much what i figured.
  7. Kevin P
    Kevin P Screenwriter
    Jan 18, 1999
    1,439
    The vary-your-speed rule is good for engines, but don't forget the brakes too. Many cars' manuals specify that you avoid hard braking for the first 500-1000 miles to allow the pads/shoes and rotors/drums to break in properly. Of course, with all the idiots on the road this will be easier said than done, but for the most part you can do it by anticipating stops or reduction in speed and not slam on the brakes if you can avoid it.
    KJP
  8. Jared_B
    Jared_B Supporting Actor
    May 7, 2001
    580
    My BMW required a 1200 miles break-in period. You were not supposed to exceed 4000rpm and not to do any full throttle starts. The whole varying speed thing also applied.
    Conversly, my last vehicle, a '99 S-10 4x4 had not specific break-in procedure. It had the low-tech push rod V6, while my BMW has a variable valve timing DOHC V8.
  9. Alex Prosak
    Alex Prosak Supporting Actor
    Dec 9, 2001
    773
    Vary your speed and don't break too hard (if possible) for the first 1000 miles. Don't push the RPMs up too high (3500+) during this period as well. The RPMs may very somewhat depending on the make and model and whether the car is a stick or auto. I suggest checking some forums that would be specific to the vehicle.
  10. John Tillman
    John Tillman Supporting Actor
    Feb 2, 1999
    595
    Ditto what Todd & Kevin said. In addition, do an oil & filter change after 1000 miles. The advice for brakes applies for all new brakejobs (no panic stops for fist 500 miles).
  11. Philip_G
    Philip_G Producer
    Nov 13, 2000
    5,030
    it's kind of interesting cr mfgr's don't reccomend a break in period anymore. Motorcycles do, my bike was keep it under 5k for 500 miles then under 7k until 900 miles, varying RPM when you can. I do about the same for cars.
  12. Jeremy Allin
    Jeremy Allin Supporting Actor
    Oct 6, 2001
    895
  13. Craig Robertson
    Craig Robertson Supporting Actor
    May 12, 1999
    982
    i like a good shagging in the back seat.[​IMG]
  14. Ken Garrison
    Ken Garrison Supporting Actor
    Jun 1, 2002
    543
    When I had my engine on my 84 Toyota Van rebuilt, it needed a break in period. They told us to drive it like normal. I took it easy though. After about 500 miles, then you should have the oil changed. A few metal shavings in the oil will be normal with a new engine. My engine was pretty tight when it was rebuilt. Now it's loosened up and my power is a little better. Wish I had even more power. Anyway, just take a bit easy on the first few hundred miles.
  15. Todd Hochard
    Jan 24, 1999
    2,312
  16. Ken Garrison
    Jun 1, 2002
    543
    My brakes were also re-done during the rebuild. But WhyTF do they squeak when I'm backing up and I'm using my brakes to keep the backing up speed under control?
  17. Philip Hamm
    Philip Hamm Lead Actor
    Jan 23, 1999
    6,873
    2
    The owner's manual probably has the best advice. The engineers who built your car know better than a bunch of clowns on the internet. [​IMG]
  18. John Tillman
    Feb 2, 1999
    595
    Philip, have you been withholding your membership checks? They seem to be punishing you by lowering your post count. It's like you're deep into a Florida election or something [​IMG].
  19. Philip_G
    Philip_G Producer
    Nov 13, 2000
    5,030
    I can't recall seing a break in section in either of the last 2 new cars I purchased philip.
  20. Josh Lowe
    Jun 19, 2002
    1,063
    brakes are a totally different thing than an engine. bedding in new brakes is very important to guarantee that they are as effective as possible and increase pad/rotor life.
    these instructions from Baer on how to properly bed in new brakes on a street car are good:
    http://www.baer.com/bedding_street/
