How do they store space past the dvd's capacity
Discussion in 'DVD' started by Ken Burkstrum, Nov 11, 2005.
  1. Ken Burkstrum
    Ken Burkstrum Stunt Coordinator
    Dec 19, 2003
    149
    I noticed with every dvd I put in the comp it says it has more then then the 4.7GB of DVD capacity, sometimes anywhere up to 10, how is that? I thought you needed a double layer DVD player to play double layer DVDs so im not sure that's what it is. Do they still use 4.7GB DVDs to fit movies and if so how are they cramming so much space in there.
    It just occured to me that if CDs only have 700MB and I have CDs with more then 20 tracks running at 1411Kbps, how in the heck do they fit on there?
  2. Holadem
    Holadem Lead Actor
    Nov 4, 2000
    8,967
    That's the problem right there, you don't [​IMG].
    Most commercial DVDs are double layer discs.
    H
  3. Ken Burkstrum
    Dec 19, 2003
    149
    and CDs?
  4. Jesse Blacklow
    Jesse Blacklow Cinematographer
    Oct 14, 2002
    2,049
    No, all CDs are limited to either 72min/650MB or 80min/700MB.
    Also, there's several different types of DVDs, all of which are playable in any DVD player or DVD-ROM drive:
    • Single-sided single-layer (4.7GB, what most recordable DVDs come in)
    • Single-sided dual-layer (~9GB, most commercial DVDs and DL recordable DVDs)
    • Dual-sided single-layer (aka the hated "flippers" and now rarely used)
    • Dual-sided dual-layer (aka DVD-18, as in GB. Used often by Universal for long movies or TV on DVD).
  5. Cameron Yee
    Cameron Yee Executive Producer
    May 9, 2002
    11,680
    648
    Since 2006
    Cameron Yee
    Playback, no; burning, yes.
  6. Roger_R
    Roger_R Second Unit
    Nov 6, 2003
    372
    Data tracks on CDs waste a certain amount of space on error-checking, checksums and so on to make sure the data is read correctly. Audio tracks contain no such thing. The error-checking is instead done by the circuits of the CD-player. That's why you can put more data on a CD if you save it as audio tracks.
