How do these banana plugs work?
Discussion in 'Archived Threads 2001-2004' started by Jereme D, Dec 27, 2002.
  1. Jereme D
    Jereme D Stunt Coordinator
    Jan 29, 2002
    211
    http://www.partsexpress.com/pe/pshow...umber=091-1165
    The one's that I have right now have the hole in the side of the shaft and the piercing point. i don't really feel good about the connection, so I'm going to get some better plugs.
    How does the wire actually attach to these?
  2. Ken Custodio
    Ken Custodio Second Unit
    Dec 5, 2001
    316
    You connect the banana plugs to the speaker wire by unscrewing the bottom half of the banana plug and threading the speaker wire through the bottom half. Then you fan out the speaker wire strands and screw the top half of the plug so that it clamps down on speaker wire. If you have speaker wires with solid conductors these bananas won't work.
  3. James Elvick
    James Elvick Supporting Actor
    Jan 12, 1999
    690
    I believe that this is the same banana plug that Home Depot sells under the RCA name for $5.99 a pair. They work well.
    James
  4. Jereme D
    Jan 29, 2002
    211
    Thanks for the info. That's somewhat along the lines of what I was thinking.
