Ryan Cruz
- Apr 2, 2002
Is it because of the speaker height alone?
You'll also often find spikes or cones at the base of the stand--another isolation measure
I would think the goal of the spikes is to isolate the speakers from the floor.
Holadem
Could be true if your floor vibrates quite a bit! In my view, spikes on speaker stands (or towers for that matter) do the opposite of isolation from the floor and that they actually couple the speaker to the floor below if you have carpeting. Particularly useful if you have very shaggy carpet!! Spikes usually work better if there is plywood or hardwood underneath the carpeting. Some spike users report chattering if the flooring beneath is concrete b/c the spikes have nothing to grab onto -- more so a problem with subwoofers and fuller-range speakers.
Anyway, another advantage of spikes is that you can angle the speaker to the listening position by using different lengths of spikes on the front and rears of the speaker.
Sorry for taking this slightly OT.
Todd
Actually, the floor--if you have hardwood floors (I do)--does vibrate quite a bit, especially when you have music/soundtracks that feature a lot of bass. When that big SVS (or any decent sub) in the corner starts "shaking everything in the room", you can definitely feel the vibration in the floor.
