Rodlks
- May 15, 2011
- Rod Laughlin
I have an old set of Cambridge Soundworks Ensemble speakers ... two bookshelf speakers and a woofer, each with only one set of connectors. I want to wire the speakers to a old Sony STR-DE197 receiver. The receiver speaker output has an "A" and a "B" set, each consisting of two right and left outputs, one labeled "+" and one labeled "-". How do I wire this?
The speakers say "6 ohm" and the receiver says "use 8-14 ohm." Is the mismatch a problem?
