How do I wire n' hide wire to rear speakers?
Discussion in 'Home Theater Projects' started by JeanVanDam, Dec 4, 2003.
  1. JeanVanDam
    JeanVanDam Stunt Coordinator
    Dec 2, 2003
    51
    What's the best way to run and hide speaker wires to rear mounted speakers?[​IMG]
  2. Michael Reuben
    Michael Reuben Studio Mogul
    Feb 12, 1998
    21,763
    2
    I'm moving this to the Construction and Interiors section. But you're not likely to get useful answers unless you provide more information. Depending on the distance, room configuration, existing fixtures, etc., there's an enormous range of possibilities, ranging from burying the cable in the wall to simply stringing it around the room.
    M.
  3. Nick P
    Nick P Second Unit
    Feb 11, 2001
    270
    Plastic wire channel from Home Depot works pretty well. Just run it along your baseboards and then pass it up through your wall to the speaker.
  4. Philip Hamm
    Philip Hamm Lead Actor
    Jan 23, 1999
    6,873
    2
    The "best way" is to put the wire in the framing before the drywall goes on. Other than that I don't know any other ways.
  5. Wayne A. Pflughaupt
    Aug 5, 1999
    6,123
    40
    6,610
    Katy, TX
    Wayne
  6. JeanVanDam
    Dec 2, 2003
    51
    Thanks![​IMG]
  7. Chris White
    Chris White Second Unit
    Feb 12, 1999
    391
    You can also run the wire next to the ceiling and then install molding. For example, we used a small strip of molding to cover the wiring to our side surrounds. Here you see half the molding installed.
    [​IMG]
