How do I turn off Red Push on new model Wega? (1 Viewer)
I recently bought Sony's KV32FS320 TV. It's the newer model so the 2 values that are needed to change the TV's red push switch are not available.
Does anybody know which switch(es) in service mode I look need to look for in my late model Sony?
For those who have the same question I found out it is the MTRX parameter.
But even after putting that to zero, the red is still too high according to Avia's calibration tests.
Mary M S
Mitch, I am not familar with your service menu. But had the same issue with my LCD GW. At that time I was using the component inputs on my display. I changed out a "Monster" componet cable for (I believe) "Better Cable" set, either BC's bottom line or mid range. (they had 3 levels - good/better/best.) Problem disappeard. It was the Monster cables (I had two sets of the Monster Component, - both exhibited this issue.) YMMV
aotorusxwxr
