how do i transfer cached webpages to pocket pc
Discussion in 'Computers' started by Len Cheong, Feb 28, 2005.
  1. Len Cheong
    Len Cheong Second Unit
    Mar 18, 2000
    372
    does anybody know how to do this?
    i want to be able to view stuff offline on my pocket pc.
    Can I do this through activesync?
  2. Kimmo Jaskari
    Kimmo Jaskari Screenwriter
    Feb 27, 2000
    1,528
    You might want to check out Avantgo http://www.avantgo.com
    That's designed for offline viewing of web content.
    From what it says on the web page you can create custom channels.
  3. Robert_Gaither
    Robert_Gaither Screenwriter
    Mar 12, 2002
    1,370
    Len can you give us a little more of your setup and how you want to go about it (ie is your pocket pc bluetooth, wifi, or mobile edition) etc?
  4. Kimmo Jaskari
    Feb 27, 2000
    1,528
    The easy way to get stuff to the Pocket PC is to place it in a sub-folder of the sync folder in My Documents on the PC.
    If that isn't active, you can activate file syncing via the Tools / Options menus in Activesync. That just copies raw data, usually, though; it doesn't format it for offline viewing. Well, it can convert Microsoft formats into the lame-duck Pocket Word etc formats, but that carves out many things from the document; hardly helpful in most circumstances.
  5. Len Cheong
    Mar 18, 2000
    372
    Thanks for the replies,
    Kimmo, i put a personal folder in my activesync files and
    saved webpages in this folder. After syncing with my pocket pc, it showed up offline in it. Now when Im offline I can browse these pages. Thanks.
