Derek B
- Feb 11, 2001
OK, I finally got the Pioneer SD-643HD5 64" HD monitor. I am very happy with it so far. I have not received my Avia or Digital Video Essentials calibration DVD's yet so I have winged it.
I was still a little frustrated that the HD channels do not always broadcast a true 16x9 picture to fill my screen. Only some shows truly fill the entire TV while others give the black bars on the left and right. I guess I will have to get used to that.
The HD channels truly look AWESOME! But here is my problem. When I adjust my picture settings for on the HD channels, it also affects the non-HD channels since they are on the same Video input. Therefore the non-HD channels end up looking "not that great". I know you will tell me that "Its because you have a high resolution HD TV and you were just never able to see these artifacts on your small 25" CRT", but this looks pretty bad. I am sending a 480i signal to the TV for the non-HD channels through component video. 1080i is sent to the TV for the HD channels through component video. My TV is supposed to take the 480i signal and create a 480p signal and make them look a lot better, but it does not seem to be doing that. Maybe I have one parameter on my TV set incorrectly? Can someone give me thoughts on what might help my problem.
One other thing, When I watch a Widescreen DVD (i.e. "The Italian Job") with the TV set to Full Screen, It only fills about half the TV with BIG bars on top and bottom. Am I going to experience this with all Widescreen DVD's or are there many Different Aspect ratios for "Widescreen"? I know I can use Zoom on the DVD player, or set the TV to "Cinema Wide", but then I lose some of the picture and the quality is not quite as good.
