how do I set up my radio pre-set on my yamaha 1400?
Discussion in 'AV Receivers' started by Joe_on, Aug 6, 2004.
  1. Joe_on
    Joe_on Stunt Coordinator
    Aug 10, 2003
    52
    I have tried to set up my fav stations on FM on my yammy 1400 and when I do it and return to see if its works, it doesnt work.
    I called the shop I bought it and they said , it's too complicated to help you on the phone, you have to make a trip to the store. I almost fell off my chair, are you serious? I told them, they were.
    I see that there are five groups , ABCDE and I understand that each group , you can add 5 stations. I go to group one, and it shows A1, I choose the station and it gives gives me a colon, then I press edit, get rid of the colon and then I press memory. I do it for 5 stations, but when I go back, there is nothing, nada.
    What am I doing wrong? can someone breakdown the steps for me? Thanks in advance.
  2. Joe_on
    Aug 10, 2003
    52
    come'on not one person has set up their pre-set stations?
  3. Wayne A. Pflughaupt
    Aug 5, 1999
    6,098
    33
    Katy, TX
    Wayne
    The on-line manual for recent model RX-V3200 shows separate procedures for automatic vs. manual tuning. It sounds like you might be trying to mix the two. The “Edit” button is only used for automatic tuning.
    For manual tuning:
    1. Tune in station.
    2. Press Memory. The Memory indicator light will flash for a few seconds.
    3. Press A/B/C/D/E repeatedly to select the desired station group.
    4. Press Preset/Tuning < > to select a pre-set station number.
    5. Press Memory on the front panel while the Memory indicator light is flashing.
    6. Repeat steps 1-5 to store other stations.
    Hope this helps.
    Wayne A. Pflughaupt
  4. Joe_on
    Aug 10, 2003
    52
    Thanks!
