vinson
- Oct 17, 2003
This is a stupid question but it's my first time owning a receiver. I'm wondering what the right way to hook up my tv and cable to my receiver. I do not have a cable box with component outputs. I do have a Denon 3803 receiver. So is the correct way to hook up everything is to hook up the cable to the tv and then hook the tv out to the receiver inputs and then also to hook up the receiver output back to the tv input?
Or is there a way to hook the cable to the receiver and then hook up the tv to the receiver? There is a coaxial input on the receiver but it says its for fm signals so I'm not sure if I'm supposed to hook up my cable to that.
Your help would be appreciated.
