How do I hook up a Fidek 3002 amp?
Discussion in 'Archived Threads 2001-2004' started by JasonWaddington, Aug 21, 2002.
  1. JasonWaddington
    JasonWaddington Stunt Coordinator
    Aug 7, 2002
    120
    Its the one that used to come with SVS. It has two connectors on the back, one looks like a headphone jack and the other looks like a three pronged computer cable. How do I connect this to my receiver? I assume I run a y-connector from the receiver to the two channels, but what sort of cable do I use between the receiver and the amp???
  2. Brian Schucher
    Brian Schucher Supporting Actor
    Nov 22, 2000
    700
    you need to get 1/4 phono plug to RCA adapters. Radio Shack sells em for a cpl bucks..
  3. JasonWaddington
    Aug 7, 2002
    120
  4. JasonWaddington
    Aug 7, 2002
    120
    I am going to receive two SVS 25-31cs subs tommorow. I already have the amp, but i want to know what kind of speaker cable is best to connect the amp to the subs? Do I need thick cable or will some fairly thin cable do the job? Also, do I need a nice y connector to split the signal from the lfe? and do I need nice rca to 1/4" interconnects? or should I use a rca to 1/4" adapter and nice subwoofer cable? do the cables really matter?
  5. EarleD
    EarleD Supporting Actor
    Aug 27, 2000
    728
    3
    Jason,
    I have a nice Monster RCA to 1/4 13 ft cord. Would let it go for $25 shipped to you.
    LMK
    Earle
    I would include all neccesary cords for connection to your amps so that you could use both channels.
  6. EarleD
    Aug 27, 2000
    728
    3
    Plus an extra ziener dioode I have laying around so that you can do the Fidek Fix.
  7. JasonWaddington
    Aug 7, 2002
    120
    sounds like a deal. do you live in wallingford seattle?...if so i can make it by today after the NEC and pick it up with the cash on the spot. just email mail your address to me at [email protected]
    thanks!
  8. EarleD
    Aug 27, 2000
    728
    3
