Donald_S
- Oct 19, 2003
I'm shortly going to make the plunge and purchase a rear projection TV (a 50" DLP or LCD). But I'm really struggling with what to do about sound. I have no actual limit on what I can spend, but I couldn't look at myself in the mirror if I spent $5,000 on sound. I've looked at a number of "in a box" systems but everyone seems to turn up their nose at them.
I've researched a number of matched speaker systems including the Onkyo HT-S660, the Klipsch Quintet, the Harmon Kardon HKTS 12, the Fluance AV-HTB, and most expensive of the lot, the Onix Rockets.
Everyone says *exactly* the same thing "Great sound for the money, sounds better than speakers twice the price".
So I have two big problems, first I need to educate my ear so that I can even judge if it makes a significant difference to me, or whether a HTIB system will do just as well. How do I do that? What do I look for? Are things like efficiency important? I hear about 'better dynamic range' and 'purer base'. Those are just words to me. How do I educate myself so I can make a decision on whether it's worth spending the money on the Rockets (or something even groovier)?
Second, most of the speakers listed above you can't listen to at the local store. And paying $300 in shipping there and back is an expensive way to try them out. How do you guys deal with this problem?
And third, now that I think of it, does anyone have opinions on the systems I've listed (the Rockets aside, I assume everyone would just say, buy them). Does anyone think they be good enough to do for a few years, or are they immediate replacement material? I've got a 17x13 room that is open on one side and a vaulted ceiling, so there is some air space to fill.
Thanks a bunch in advance for reading my long ramble and for any input.
Donald
Donald
