How do I get to the Light cannons on a Sony KPSW520 T.V. (1 Viewer)
Jerome Grate
One strand of spider web going across the guns and you can see it on the t.v. on white or bright solid screens. Can someone tell me how to open it just to clean the web off and dust the guns. Also, what kind of clearner can be used to clean the guns.
Dave H
I have the same display.
From the back of the TV, unscrew the board (maybe 10-12 screws).
Once you remove it, there will be a smaller board inside the set which easily slides out.
You will then have clear access to the CRTs.
Chris' link provides good cleaning info.
kiwipip
